SE Turbo Upgrade
blackster
SE Turbo Upgrade
Postby blackster » Thu Feb 01, 2007 11:54 pm
We are replacing the stock manifold and turbo. Disco Potato time! It will retail the stock Intercooler / BEGi Intercooler location and IC outlet tube.
http://bellengineering.net/Pages/intheshop.html
Looks like the guys from BEGi, have stepped infront of FM.
Previous
04' MX5 SE.
02' MX5 Classic ed.
jules
Guitar Hero
Postby jules » Fri Feb 02, 2007 10:13 am
Perhaps, although then SE's are getting fairly cheap now and have plenty of goodies thrown in as well as a baby turbo.
It would possibly be cheaper to just grab an SP though.
Jules
Postby bruce » Fri Feb 02, 2007 10:49 am
Luv the airbox.
CT
Postby CT » Fri Feb 02, 2007 11:26 am
If you are that keen, just get the standard turbo modified. That way it remains standard looking and mount wise but has higher capacity internals. The stocky one will easily do 150rwkw at less than 1 bar of boost so until you are running up there, you are well away from the limit on the stock setup. All Begi have really done is copy the SP/AVO setup by the look of it. Nice and neat though. 8)
blackster
Postby blackster » Fri Feb 02, 2007 8:48 pm
CT wrote:just get the standard turbo modified.
Out of curiosity who do you suggest to do such work?
Previous
04' MX5 SE.
02' MX5 Classic ed.
Casey
Postby Casey » Fri Feb 02, 2007 8:52 pm
CT wrote:If you are that keen, just get the standard turbo modified. That way it remains standard looking and mount wise but has higher capacity internals. The stocky one will easily do 150rwkw at less than 1 bar of boost so until you are running up there, you are well away from the limit on the stock setup. All Begi have really done is copy the SP/AVO setup by the look of it. Nice and neat though. 8)
I was going to say it looks like they've made it into an SP. Manifold doesn't look as nice though, but it could just be a prototype (the prototype SP manifold was a real roughy too).
White SP Image
CT
Postby CT » Sat Feb 03, 2007 5:06 pm
http://www.gcg.com.au/
There are plenty of others that also do it - just buy a fast 4s or zoom or similar mag and read the ads. There's plenty of people that can modify turbos around.
Sean
Postby Sean » Mon Feb 05, 2007 12:02 am
I've heard good things about GCG, another company I'd highly recommend are MTQ, I've had work done by MTQ when they had a branch close to me and the work was top grade with reasonable pricing, gave me back all the old bits too..
