billet pulley's
16bit
Vehicle: NB8A - Supercharged
billet pulley's
Postby 16bit » Thu Jan 25, 2007 12:35 pm
has anyone made this addition to their 5? I was thinking of doing it when i put my new belt on. I have seen a few bits for na6's but does anyone know of one for a nb8a?
StanTheMan
Postby StanTheMan » Thu Jan 25, 2007 12:47 pm
I have not done it to a MX5
I did do it to a Morris Minor, after breaking a crankshaft. I put a Morris Cooper S ballancer on it. It was supposed to prevent the cranckshaft from breaking. It was mutch heavier.
It reved a lot smoother........but the cranckshaft eventually broke a 2nd time.
I then replaced a 948ccm motor with a 1100 sprite motor( i don't think there is such a thing its just an 1100 motor with all the sprite go fast bits.)It had a standard pulley on it.
The crankshaft never brocke again.
I'd personally stay away from it.
16bit
Postby 16bit » Thu Jan 25, 2007 12:58 pm
i see your point, the crank is ballanced for that weight of pulley etc. thanks for the advice!
Sheck
Postby Sheck » Thu Jan 25, 2007 1:23 pm
Dont touch them unless they are balanced and made by a reputable company. Otherwise a pulley for the water pump would be fine. :D
Dave
The Pupat
Postby The Pupat » Thu Jan 25, 2007 5:27 pm
Why would you even bother?
The only reason I see to do it is to underdrive the water pump, alternator etc. It's the only way to actually make more grunt.
Sheck
Postby Sheck » Thu Jan 25, 2007 5:38 pm
Thats what i was thinkin, also prevents water cavitation at sustained high rpm
