I plan on doing this in the driveway or lawn or at someone's house for a dodgy day... DID SOMEONE SAY DOGY DAY?!?!?!
I'll hit MX5Parts and see what sort of price i'm looking at in buying all this stuff.
Looking in this thread and this Miata.net page for the 2001 model service, I have the following list:
- Air filter clean
Fuel filter
CHECK Plugs and leads (not that old)
Brake and clutch hydraulic systems flush
Coolant flush
Timing belt
Water pump + gaskets
Cam and crank seals
Valve cover gasket
alternator belt
a/c - p/s belt
Gear box oil
Engine oil and filter
Gearstick top and lower hats
Exhaust gaskets (the never ending leaking SPM exhaust)
Install short shifter
Some things that i'm a little confused about are these suggestions:
- Idler pulley
tensioner pulley
tensioner spring
OCV Orings
OCV oil pipe washers
Can anyone shed any light on this list and make anymore suggestions on what else there is? Thanks all.
