quad throttle bodies for road car
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Thu Jan 11, 2007 5:37 pm
Is this legal to start with and if so who has done it and how much did it cost.
There is a set for sale on mania second hand but they look a little dodgy.
Will it even be worth it for the hp gained?
Sheck
Postby Sheck » Thu Jan 11, 2007 6:08 pm
Is it leagal?
Depends where you live i think, even then it will have to be mod plated (which possibly means an emissions check)
Dodgy looking?
Are they on the website? Cant see them anywhere..
Worth is for the hp?
Depends on what you mean by worth it, if you are expecting a lot of power out of these - then no.
If you are expecting awesome throttle response and drool worthy intake sound - then HELL YES!!!!
You gotta look at supporting mods for this too, like (most likely) a new computer, and possibly a box thingy around the trumpets to pass modding??
There will be plenty of other helpful tips from the guys on here with the same mod, so it's best to listen to them :mrgreen:
Dave
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Thu Jan 11, 2007 7:02 pm
Sheck has it all pretty right...
To make use of the throttle bodies you need to do head and cams and computer,extractors,ends up costing heaps...and without building a good bottom end you will be lucky to get over 100rwkw...
Best just to fit turbo...
CT
Postby CT » Thu Jan 11, 2007 7:51 pm
But if you are looking for a quad throttle manifold to suit an early 1.8 - let me know. I have a brand new one sitting in the shed. 8)
greenMachine
Postby greenMachine » Thu Jan 11, 2007 9:44 pm
That's a tad pessimistic Lou :wink:
Maybe a couple of Kw, better throttle response, and a LOVERLY noise ... but if you haven't done the things mentioned above, its not worth it performance wise.
I think I have just talked myself into something - CT, you have mail :roll:
16bit
Postby 16bit » Fri Jan 12, 2007 9:19 am
thanks guys - getting the exhaust this weekend but will probably get lsd and some lower springs before i do cams and comp.
