Rear Muffler Replacement? Recomendations
Boags
Postby Boags » Sat Jan 06, 2007 10:58 am
I think you have to run it like that if you want to relocate the spare. A new tip and muffler shouldn't set you back much more than $200, a lot less if you get the right place and right muffler. You will have a hole in the bumper from where the old tip used to be though, so it might look a little untidy. Just keep it in mind!
I got my new muffler and tip from Rob Bliss exhausts on the north side of brissy ($180 fitted with new gasket for cat), they are the shop that worked with Loch Stewart to design the NA gear! 8)
Boags
trader
rear muffler replacement
Postby trader » Sat Jan 06, 2007 12:27 pm
I have done the relocating trick and used 2 1/4 inch piping with supercat muffler. I did that size as I thought at the time I would turbo but probably wont now. The problem I found was its too loud (I have extractors and CAI) and I had to put two 2ft hot dogs in to stop the drone. I've since made up a removable baffle which has quitened it down especially around 4000 rpm. If I did it again I would use 2\" and probably use a lukey walker L0099 (listen to it on autospeed.drive.com.au) with the same lenght hotdog. Shouldnt cost too much as muffler is around $80.
Relocating the spare still has two doglegs in the pipe but is the only way it can be done.
NB SE, NA 1.8.
STV
Postby STV » Sat Jan 06, 2007 2:18 pm
the only other thing that i have done is...
if you are a dwarf like me (5 foot 7ish) the spare can actually be slid in behind the drivers seat and is still in the perfect position (for me)
give it a try if you are a short-ass or sit quite straight.
STV
Where is 'Home Sweet Home'?
AJ
Postby AJ » Sat Jan 06, 2007 4:46 pm
kev is a short ar$e............ :lol: :mrgreen:
XMX5 Rogues
Postby bruce » Thu Jan 11, 2007 11:28 am
Why don't you ditch the spare and go for the 'spare in a can'? Ask yourself how often do you get a flat?
