Thermo Fan Removal ?????
tasroadster
Postby tasroadster » Tue Jan 02, 2007 7:26 pm
I am attempting fitting an Intercooler to a NA6 1990 with A/C.
If it is possible to remove one of the thermo fans at the back of the radiator ?? ...... and just one single fan ?????
It would make the job MUCH easier. ie. provide much need room for the intercooler pipes to be routed down to the Intercooler.
Thanks for your help.
Regards
Fatty
Postby Fatty » Tue Jan 02, 2007 8:44 pm
common practice when installing a turbo on an na6 is to wire both fans in parralel to provide extra cooling to your radiator. remember, your cooling system will be working overtime once you install a turbo.
therefore i don't think it's a good idea to remove the second fan.
Boags
Postby Boags » Tue Jan 02, 2007 8:57 pm
I second that. Installing the piping will be a PITA unfortunately, but once it's done, it's done.
Boags
Uncle Arthur
Dodgy Award Benefactor
Postby Uncle Arthur » Tue Jan 02, 2007 10:29 pm
And removing the fans is easier with the radiator removed anyway....
So go get yourself the factory (2 core) radiator off the automatic and save yourself some hassles.....
Juffa
Postby Juffa » Wed Jan 03, 2007 8:27 am
I have air cond as well. The pipe that runs from the turbo outlet to the intercooler is oval shapped. This means that it can run down the side of the fan and not interfer with the fan, the radiator and the air cond compressor. I will try and take some pictures of the setup. I have used a lot of Silicon(e) hose in mine to get all of the angles right.
J
tasroadster
Postby tasroadster » Wed Jan 03, 2007 8:31 am
Where did you find the oval pipe ?
Pic's would be very helpful.
Thanks for that.
Regards
lowmiata
Re: Thermo Fan Removal ?????
Postby lowmiata » Wed Jan 03, 2007 9:11 pm
tasroadster wrote:I am attempting fitting an Intercooler to a NA6 1990 with A/C.
Regards
you can get the pipe down there you just have to be creative
I did sabretooths piping with the two fans on the radiator although tight to get the pipe round it can be done
oval pipe can be down many ways!
ie it can be pressed (there are cheaper ways to press it than paying to have it pressed)
How are you doing the piping? with tube bends then welding it all together?
EVI15 1998 to 2008
Juffa
Postby Juffa » Fri Jan 05, 2007 10:34 am
Ok, Here a couple of photos I took during the install process. I don't currently have a good close up shot of the oval pipe running down beside the fan, but hopefully these will give you the general idea. The main reason that I believe that the pipe needs to be oval is to clear the air cond compressor, as it clears the fan with a reasonable amount of room. Also note I have replaced the short piece of silicone hose in the photos with a hump hose to allow some movement in the setup.
J
