Has anyone sucessfully removed and refitted valvesprings without taking the head off?
I fear a big job coming on to fit my new springs
Woo wrote:Yep, just make sure you have plenty of compressed air (volume AND pressure) and a good pair of earplugs.
IMHO don't even contemplate it without at least 5 CFM @ 90psi
Cranking the pot to TDC just incase you drop the valve is also a good idea.
Of course you'll need a tounge spring clamp, but I suppose a large ringy would suffice.
Sean wrote:We have a HUGE compressor capable of supplying plenty or air (the thing is nearly as big as the car!)
My concern is getting the spring compressors onto something to compress the spirngs. On the last head I did it with head removed and just tightened the compressor onto the combustion chamber side - if you get what i mean?
Sean wrote:Basically get a big deep socket (like used formage wheels) and place it on teh retainer with the head on the bench with a couple of rubber mats below it.
Than WHACK it hard with a big hammer
Brett_MX5 wrote:Would one of these work ??
Babalouie wrote:Not sure if there is the room to use one of those on an MX5 head...would work on a Honda head since they have a rocker arm you can remove but on our heads there is a lifter boss in the way....
