Grinding Noice On Clutch Application
mightyrollaman wrote:JBT wrote:Worn throwout bearing. Sometimes called a clutch release bearing. Works like this. Normally part of a clutch kit.
Here, here. Also known as a thrust bearing. Best to replace the clutch while you've got it all apart.
Don't forget to replace the spigot bearing as well while its all apart.
Andrew.
Previously, White 95 NA 1.8 Hard Top,Stock standard
Now, 2016 Fiat 500x, 2014 Fiat 500, 2015 ND GT 2.0
