Slipping clutch - need help/advice
JSE
Postby JSE » Sat Nov 25, 2006 5:55 pm
my clutch is slipping majorly. It only does it after about 45mins of driving or on very hot days (like lately in Sydney). What is the problem, can it be fixed, do i need a new clutch and what should I do?
If I need a new clutch i will be putting in a beefy heavy duty one (if that answers any future questions/posts).
thanks in advance
zoomzoom
Postby zoomzoom » Sun Nov 26, 2006 3:04 pm
Have you checked your oil lately? Perhaps when the car warms up and the oil thins it can get through the rear main oil seal faster and get onto your clutch. Anyhow leaky rear main or not its only a matter of time before you need a new clutch all together so I would start saving/planning now. And while your there you might as well do the rear main too.
JBT
Re: Slipping clutch - need help/advice
Postby JBT » Sun Nov 26, 2006 3:33 pm
JSE wrote: What is the problem, can it be fixed, do i need a new clutch and what should I do?
a. stuffed clutch;
b. yes:
c. yes; and
d. get a new clutch kit , pilot bearing and rear engine seal and have them fitted.
JSE
Postby JSE » Sun Nov 26, 2006 7:31 pm
thanks...so has nothing to do with the master & slave cylinders?
AJ
Postby AJ » Sun Nov 26, 2006 8:07 pm
given the age of the car, a new clutch & pressure plate will probly mean both those need doing in the coming months
XMX5 Rogues
JBT
Postby JBT » Sun Nov 26, 2006 8:45 pm
JSE wrote:thanks...so has nothing to do with the master & slave cylinders?
Not if you mean clutch slip as in the clutch allows you to engage gears but engine RPM changes without any immediate change in speed - a bit like an automatic car struggling to accelerate in Drive. Generally noticed when going up an incline in a slightly higher gear than you would like to be in.
JSE
Postby JSE » Sun Nov 26, 2006 9:50 pm
yep...
also when i take off in 1st gear from a standstill...when i release the clutch with my foot the whole car shakes violently. like its going crazy until it grabs the gear. another problem or the same sort of thing?
AJ
Postby AJ » Sun Nov 26, 2006 9:55 pm
nah, that's the poor old clutch trying to grab hold with what little it has left........you've got the maximum life out of it by the sounds............of course oil leaking from the rear main would cause the same effect, same prognosis tho...........new clutch assembly :?
XMX5 Rogues
john!
Postby john! » Mon Nov 27, 2006 7:38 am
AJ wrote:nah, that's the poor old clutch trying to grab hold with what little it has left........you've got the maximum life out of it by the sounds............of course oil leaking from the rear main would cause the same effect, same prognosis tho...........new clutch assembly :?
Hmmm, can't seem to recall my clutch doing that when it was nearly dead.
It might be worth having a check of your engine mounts as well, especially on an older car. The shaking they make sounds like what you have described. They are going to look like this if they are gone, big crack in the rubber bits.
john
JSE
Postby JSE » Mon Nov 27, 2006 11:16 am
Hmmm i hope not since i replaced my mounts 6 months ago :?
Andy Wana
Postby Andy Wana » Tue Nov 28, 2006 11:34 am
Is a new clutch assembly costly to install?
I ♥ asymmetry
CT
Postby CT » Tue Nov 28, 2006 3:05 pm
Not really but to get at it you have to drop the gearbox which is a couple of hours labour at best.
jules
Guitar Hero
Postby jules » Tue Nov 28, 2006 5:43 pm
And just sooooo much fun on a little, low to the ground 5. Isn't it Uncle Arthur?
Jules
MasterZ
Postby MasterZ » Tue Nov 28, 2006 8:03 pm
my clutch was slipping once. but it was my fault. i had a freebie in class and we went to bass point (big gravel spot) and we were having fun doing donuts and crap. but by the end of the day, it was back to normal
1992 Mazda MX5 Turbo | 2004 VW Golf GTI | 2010.5 VW R36 Passat Wagon | 1985 Mazda HBES 929 13b Turbo | 1987 Mazda RX7 FC3S Turbo | KE20 Corolla Coupe
jules
Guitar Hero
Postby jules » Wed Nov 29, 2006 10:04 am
Hmmm Gravel + paint = no fun.
Jules
