Anyone got one of these lying around?
jules
Guitar Hero
Postby jules » Tue Nov 14, 2006 1:52 pm
I've been having issues with my A/C being \"sorta\" cold.
This compressor is pretty noisy, whirring and whining, and I think it might be the culprit.
Either that or the evaporator core. It's all cycling on and off, but is not freezing anymore, just almost cold enough.
It's a Sanden SD7H13 7317/8909 and I think it is about to die.
Apparently these are quite good units and use a lot less power than the Mazda standard compressor.
I'm just making an assumption that this is the issue due to the whole system still working, but only at about 65% cool. If anyone has another opinion, then I'm all ears.
Sorry about the large image sizes. Has anyone got one lying around or a similar unit that may suit they want to offload?
Thanks
Jules
Fuzzlet
Postby Fuzzlet » Tue Nov 14, 2006 9:52 pm
When was the system last gassed? could be that
jules
Guitar Hero
Postby jules » Tue Nov 14, 2006 10:36 pm
3 weeks ago. My mates an Auto Electrician.
He told me the compressor didn't look great, but it was running a lot colder than it is now.
Jules
Uncle Arthur
Dodgy Award Benefactor
Re: Anyone got one of these lying around?
Postby Uncle Arthur » Tue Nov 14, 2006 11:45 pm
jules wrote:I've been having issues with my A/C being "sorta" cold.
Thanks
Jules
Jules - I have exactly the same problem - perhaps we should pool some resources to find a solution???
jules
Guitar Hero
Postby jules » Wed Nov 15, 2006 9:36 am
So back to the sparky then?
Jules
adfox
Postby adfox » Wed Nov 15, 2006 11:15 am
I'm pretty sure there is a thermostat on the heat exchanger core in the car that you can adjust that sets the temp at which the compressor kicks in and out.
jules
Guitar Hero
Postby jules » Wed Nov 15, 2006 12:23 pm
Yeah, that would be the one with the knob on top? The compressor is kicking in though?
Can I just turn that up?
Jules
adfox
Postby adfox » Wed Nov 15, 2006 12:34 pm
I'm not 100% sure about adjusting it, I haven't done it myself. I would maybe just try turning it a bit with the aircon on, and a temp probe in the core. Check your current core temp and have a play with it. Just don't freeze the whole thing up! :D
jules
Guitar Hero
Postby jules » Wed Nov 15, 2006 12:38 pm
To touch the airbox is cold on the cabin side, but ambient temp in the engine side. I don't know if this means anything though :?
Jules
adfox
Postby adfox » Wed Nov 15, 2006 1:03 pm
Hmm not sure, I think you really need a temp probe to get any meaningful data. I think my skyline measured about 7 deg at the vent with the fan on full. It could be a bit colder though, it just keeps you comfortable on a hot day.
jules
Guitar Hero
Postby jules » Wed Nov 15, 2006 1:40 pm
When mine was gassed up it was reading 11 degrees at the centre vents. The top was down though. They thought the compressor might not take anymore.
Jules
Garry
Postby Garry » Wed Nov 15, 2006 2:45 pm
It should be around 5 to 7 degrees inside the centre air vents. If you adjust the thermostat to much then the evaporator could freeze up. Which you dont really want to happen.
jules
Guitar Hero
Postby jules » Thu Nov 16, 2006 4:17 pm
I've turned the thermostat all the way to full. The compressor kicks in and stays in :D :D It feels a fair bit colder now as the compressor is not switching off when the car is at standstill.
I'll get a reading if possible on Saturday to observe the temps. Hopefully I won't destroy the evaporator, but I feel it's not blisteringly cold at the moment.
Jules
adfox
Postby adfox » Fri Nov 17, 2006 2:40 pm
I'd back it off a bit, if you freeze it up you will be in all sorts of strife. The compressor should cycle on and off. You should do the testing at around 2500 rpm too, as the compressor is working much more effectively at driving revs.
jules
Guitar Hero
Postby jules » Fri Nov 17, 2006 3:06 pm
Thanks adfox. I'll back it off a bit. It was at about 6.5/7 out of 10 before I turned it up all the way.
Jules
