coolant pipe removal
mossy
Postby mossy » Fri Nov 10, 2006 5:48 pm
How can i remove this coolant pipe, i thought I read someone it just pulls out but I thought I'd better check first!
Juffa
Postby Juffa » Fri Nov 10, 2006 7:46 pm
Yes, it does pull out of the housing. There is a rubber seal around the end of the pipe that holds it in place. The pipe also has a bracket about half way along that is held in place by a exhaust manifold stud. You may need to remove the manifold, or at least loosen it enough to remove the pipe.
J
Sean
Postby Sean » Sat Nov 11, 2006 10:48 pm
I concur, make sure the nut is off teh relevant stud than just yank it out, can be fairly tight if it hasn't been out before. I'd also suggest using a new o'ring seal when you re-fit.
mossy
Postby mossy » Sun Nov 12, 2006 8:05 pm
Got it! Now I hope this thing can be cut and shut.
Sean
Postby Sean » Sun Nov 12, 2006 9:31 pm
mossy wrote:Got it! Now I hope this thing can be cut and shut.
Many have done so before 8)
