Looky what i broke!!!
Sheck
Postby Sheck » Wed Nov 08, 2006 2:34 pm
Hey guys,
I found out what that knocking noise was:
on My way home from work today, heard this loud ticking sound. My reaction is SH*T!!!! so i pulled over right away. The noise went away.
Open the bonnet to find the above pictures.
Cant belive the bolts actually sheered right off!!! Must of had the water pump belt too tight damn!
Dave
SuperMazdaKart
Postby SuperMazdaKart » Wed Nov 08, 2006 2:40 pm
ouchy, doesn't look like loctite will fix that particular problem. new cog/sprocket whichever it's called.
who did the waterpump install
mickfred
Postby mickfred » Wed Nov 08, 2006 2:41 pm
bugga!
YEAH BABY!
Boags
Postby Boags » Wed Nov 08, 2006 3:52 pm
:shock:
AJ
Postby AJ » Wed Nov 08, 2006 4:53 pm
ouch!!......b@st@rd of a spot to get the easyout into as well :?
XMX5 Rogues
StanTheMan
Postby StanTheMan » Wed Nov 08, 2006 5:01 pm
oh well......I'm sure thats fixable. just need to redo your timing belt. & get that sprocket replaced. repacle the bolt with a new one on this short nose crank. Still a real bummer.
kitkat
Postby kitkat » Wed Nov 08, 2006 5:43 pm
:shock: WOW
Well im sure you'll be pleased to know that the timing gear / key / bolt will only cost about $50 from Mazda.
Sheck
Postby Sheck » Wed Nov 08, 2006 6:39 pm
Yea cheers boys, belt is only 3-600km old (yes very new) water pump is prolly more like 20,000km and the bolt, timing gear, key, seal are about 5-10,000km.
As for the pulley/harmonic balancer mazda want $270.40!!! ouch
I'll be getting a second hand one off a mate if i'm lucky (hopeing he has the same year engine).
Thanks for the quote kitkat i forgot how much i payed last time for that stuff. I'll have to order it in tomorow.
Still cant belive it happened!! hahah
Only just got out of the garage too, got all the stuff off i needed to, so new stuff is ready to go in.
Dave
PS if you niticed that electrical tape around that hose goin from the thremostat to mani then yes i will be replacing it :mrgreen: just havent got around to it yet. Plan was to do it this arve along with my oil change.
sabretooth
Postby sabretooth » Thu Nov 09, 2006 12:34 am
Pulling the bolts out of the cog will be easy enough once you've removed the cog from the crank. What part of the pulley is damaged though?
Actually, I have to get myself a woodruff key and that sorta stuff too. And a few bolts for holding all of the various bits and pieces on - fun fun.
StanTheMan
Postby StanTheMan » Thu Nov 09, 2006 8:05 am
harmonic ballancer? whats wrong with that?
Sheck
Postby Sheck » Thu Nov 09, 2006 8:14 am
The hole are slightly enlarged and the little cut out bit (that goes on the timing mark) is bent, also the part where the spacer head of the bolt go onto are pretty worn. I'd just feel safer if i replaced it.
The cog was loctite'ed on so that came off damaged, need a new one :?
