Just fitted my Mania Intake.. pic's
green_comet
Car Detailing Guru
Postby green_comet » Thu Nov 02, 2006 7:09 pm
Hey everyone,
I spent a couple hours today fitting the mania intake that i got. I Ran into a bit of trouble with the whiteline strut brace, it sat right in the way of where the intake had to go. I heard that a few people have had this problem.. :?
I could have bent it up from underneath but that just looked lame, and it was still fowling a little on the brace..
The solution... I machined up a couple brackets to change the height of the strutbar, so the intake could sit straighter. It worked a treat, the strutbrace dosent fowl the bonnet from closing, and the mania intake now sits the way its supposed to... :D
hope you all like..
cheers
Ryan
Craig
Postby Craig » Thu Nov 02, 2006 7:14 pm
Wouldn't that bracket pivot, negating any effect the brace would have? :? Oh and the intake looks hot! 8) :mrgreen:
mio
Postby mio » Thu Nov 02, 2006 7:17 pm
Awesome job, looks good :D
might wanna put another bolt below the strut brace so it won't move around?
green_comet
Car Detailing Guru
Postby green_comet » Thu Nov 02, 2006 7:17 pm
na na its all good, I worried about that.. but after fitting nylock nuts and doing it up nice and tight, there is no way in hell thats things pivoting..
fig
Postby fig » Thu Nov 02, 2006 7:21 pm
Craig wrote:Wouldn't that bracket pivot, negating any effect the brace would have? :? Oh and the intake looks hot! 8) :mrgreen:
I was about to say.....
Even done up tight comet, over time with the car bouncing around, it may work loose? mio's suggestion is pretty good! IMO anyway
PS Looks the $hit! :)
Then
10AE (#3062)
Now
'08 Porsche Boxster S modified ;-b
'11 Porsche Cayenne 22's FTW
'78 Porsche 911SC - Old Skool Hotness
'67 Porsche 912 - Fav!
Craig
Postby Craig » Thu Nov 02, 2006 7:28 pm
I'd be inclined to make another bracket with 2 extra holes either side of the one that mounts to the brace to triangulate it, not movement then! :mrgreen:
Russellb
RIP Nov 2014
Postby Russellb » Thu Nov 02, 2006 7:43 pm
Look Great :)
But like everyone else said Make a new bracket with 2 bolt mounting points. You may have done it up very very Tight but the small amount of flex at the shock tops ( IE less than 2mm ) the single bolt Just aint up to the Job
But that just My opinion
My ClubmanRebuild
MX5 SE Rally car is HERE :)
sab
Postby sab » Thu Nov 02, 2006 7:51 pm
Looks good Ryan! What do you think of the sound?
Regarding the brace, rotate the lot 180 deg and it should sit over the lower point of the intake, giving you more clearance. Then you can remove your extension brackets.
green_comet
Car Detailing Guru
Postby green_comet » Thu Nov 02, 2006 8:16 pm
hey sab, yeah the tried turning the whole lot 180 but it was fowling worse on the filter than the pipe. So i left it that way, and installed the brackets.
My old man is going to try make up a new bracket in his workshop, but im not really fussed. Im sure im not going to feel the difference, its all placebo effect.. :?
trader
Just fitted my mania intake
Postby trader » Fri Nov 03, 2006 4:48 pm
That looks great Ryan...just got to hide the wiper bottle! What's the bracket from the pod filter attached to, seems to be the engine...
NB SE, NA 1.8.
green_comet
Car Detailing Guru
Postby green_comet » Fri Nov 03, 2006 5:29 pm
yeah its attached to the engine as a quick fix, but im making up new brackets should be ready soon.. :)
StanTheMan
Postby StanTheMan » Fri Nov 03, 2006 8:45 pm
green_comet I'm surprised your whitline studbrace doesn't fit.
Mine fits......but i've just realised..... yours is a 1.8. mines a 1.6......maybe its because of the different size AFM meter?
i'll try to find a pic.
StanTheMan
Postby StanTheMan » Fri Nov 03, 2006 8:49 pm
I think its just like sab said......
irwin83r
Postby irwin83r » Sat Nov 04, 2006 11:27 am
looks like his has a longer section of carbon pipe going by the pics.
if your strut brace is just for blind bling factor leave it how you have it with the spacer.
if you want it to still perform its job then either weld the spacer to the top of the strut brace or make a new space that uses two holes.
even with those nuts done up to breaking point and backed off half a turn i would say the tension of the cars body flexing would push through it.. if not excess amounts atleast amounts that would lessen the already minor effects the strut brace would have.
none the less GW looks the ducks guts and i bet it sounds nice too 8)
Fatty
Postby Fatty » Sat Nov 04, 2006 2:45 pm
irwin83r wrote:.. if not excess amounts atleast amounts that would lessen the already minor effects the strut brace would have.
interesting that you say this. i remember glen73 telling me that his strut brace made a big difference to the rigidity of his car (a 1.6 na).
you think they don;t make much difference? i just bought one so i'm curious (haven't fitted it yet)
