auto trans over drive not working
- Vehicle: 10AE
Hello Redeye... Do you have a copy of the Mazda MX-5 Owner's Manual ? Info. on the operation of the automatic is on page 4 -6. Instruction re. ' Hold Mode ' is on page 4-9. But in case you don't have this book ... The little round button on the shiftlever is not an overdrive switch. It is the ' HOLD ' switch. The ' HOLD ' operates on 3rd ( D ), 2nd (S ) and 1st ( L ). But not on 4th. 4th is an overdrive gear ( o. 730 ) but the ' HOLD ' doesn't operate on 4th. gear. Hope this helps. Why your speedo. isn't working is a mystery. Cheers, slowpoke
- Vehicle: 10AE
Redeye... A Post Script.. I meant to add that to enable your (automatic ) gearbox to select 4th gear ( the o'd gear ) the HOLD Mode must be switched ' OFF. ' The HOLD light (on your dashboard ) will then NOT be illuminated. I hope that I'm making sense to you.?? It's all quite easy when you read the Mazda Manual. I feel sure that your gearbox is fine. Invariably anyone who is NOT familiar with the MX5 NB8A automatic assumes that the HOLD button is an overdrive button.. but it is NOT. slowpoke
- Gramps
Users browsing this forum: Bing [Bot] and 3 guests
