Those going turbo should have a look at this info. It tell you how many HP an injector is good for, so you don't end up going too small or way overkill.
http://www.robietherobot.com/Storm/fuelinjectorguide.htm
Basically take the flow rate (cc) and divide by 5. This is max hp for each injector.
NA 185/5 = 37
37 x 4 (cylinders) = 148hp MAX (at the engine)
Boags
Fuel Injector information for turbo app.
- Boags
- Boags
Yep, it's all on that site, that is assuming standard fuel pressure and \"normal\" fuel density.
