Coolant Capacity
Rob81w
Coolant Capacity
Postby Rob81w » Fri Oct 20, 2006 4:09 pm
Hi Guys,
Does any body know the capacity of the cooling system of a manual NA6A?
Ultra Tune reackon its 2 litres! :|
Cheers, Rob
Club # 1007
Benny
Re: Coolant Capacity
Postby Benny » Fri Oct 20, 2006 4:42 pm
Rob81w wrote:Hi Guys,
The 2 litres is only the amount of beer required to cool down the mechanic after he's fixed your car. :P
sirbob
Postby sirbob » Fri Oct 20, 2006 4:44 pm
Should be around the 4 litres is my guess... my jimny is a 1.3L with the smallest radiator i have seen in a car to date, and it holds 4 L.
If the engine was cold and the thermostat shut, then you could only get about 2L out of the colling system maybe? But you would think mechainc like ultratune would know better than that....
Now driving a Grand Vitara whilst waiting for the elusive Black SE
JBT
Postby JBT » Fri Oct 20, 2006 4:45 pm
The NA8 is six(6) litres so it will be close to something like that. Ultratune :roll:
Postby Okibi » Fri Oct 20, 2006 8:10 pm
Sheck
Postby Sheck » Sat Oct 21, 2006 11:06 am
stock manual radiator only, will hold 3.3L (going off the external dimensions only, using 1cm cubed as a mL)
auto one will hold closer to 5.3L (again off external dimensions only - so it'll be less plus its got an oil cooler line inside the bottom tank)
If the PWR one is the same dimensions but 40mm think it'll hold about 8.2L
Then you gotta add all the water galleries and heater core and water lines.
Dave
