Crownwheel and Pinion
Rob E
Postby Rob E » Tue Oct 17, 2006 3:02 pm
G'day all, i am trying to locate Mazda part number m05427110a which is crownwheel and pinion ( 4.44 final drive ratio) .....unfortunately, new part is a few too many $ - any advice on where to pick up a bargain would be appreciated :P PM is Ok if you dont want to broadcast 8)
CT
Postby CT » Tue Oct 17, 2006 4:55 pm
Try diff places. It's from an econovan or mazda B2200 and there were sh!tloads of them in circulation. My diff guy had one on his shelf, already lapped and ready to go so try the yellowpages and see how you go. 8)
Matty
Postby Matty » Tue Oct 17, 2006 10:24 pm
I've got one in my garage. No you can't have it. Found it at a van wreckers in Dandenong, as CT said from an Econovan. $250.
Look for \"M054\" stamped on the outer edge of the ring gear.
Rob E
Postby Rob E » Wed Oct 18, 2006 10:14 am
Thanks Guys 8)
flycasta
Postby flycasta » Sat Nov 04, 2006 9:56 pm
I can help you out with a s/hand 4.44:1 C.W&p if you need 1
$150 plus postage to anywhere.
Rob E
Postby Rob E » Tue Nov 07, 2006 5:50 pm
PM SENT
