Me new BOV
ASE05
Me new BOV
Postby ASE05 » Sat Oct 07, 2006 6:26 pm
I reckon it looks good without being over the top. It's a Turbosmart Dualport Kompact. Put it in last night in less than 15 mins :mrgreen:
I've gotta say though, the little trumpet that vents to the atmosphere won't be there after tomorrow morning. It sounds like a sneezing 2yr old asthmatic with a cold :oops: :evil:
Before:
After:
Closer....after:
Sing that song, puff all night long.......
JBT
Postby JBT » Sat Oct 07, 2006 6:50 pm
Those BLUE TUBES have got to go mate. Must get powerful RED ones. :)
ASE05
Postby ASE05 » Sat Oct 07, 2006 8:38 pm
Pfffft, it's red on the outside where it matters JBT, you should know that 8)
miata
Postby miata » Sat Oct 07, 2006 9:40 pm
\"Me new BOV\" is there an English translation for that?
Moderator Qld.
Life Member MX-5 Club of N.S.W. #169
Waiter, I had the soup du jour yesterday and THIS ISN'T IT!
Postby Okibi » Sat Oct 07, 2006 10:30 pm
\"'ava butchers at me BOV, it's the business\" ?
Richee
Postby Richee » Sun Oct 08, 2006 7:33 am
\"nice bit of kit, yeah\"
Mazda Tribute - its a boat
FUN-29T
Postby FUN-29T » Sun Oct 08, 2006 10:06 am
PSSSHHHHhhhhhhh..........
AJ
Postby AJ » Sun Oct 08, 2006 10:19 am
miata wrote:"Me new BOV" is there an English translation for that?
"i have installed a new Blow Off Valve on my motor car, would you care to cast your eyes over it and give me your honest appraisal???"
:roll: :roll: :roll: :roll: :lol:
bloody poms always were long winded :mrgreen:
XMX5 Rogues
Boags
Postby Boags » Sun Oct 08, 2006 1:54 pm
I'd take POM over bogan any day... :lol: :roll:
Good to see your taste is improving Derek, even if it is just the silicone and not the paint job.... YET!
Boags
blackster
Re: Me new BOV
Postby blackster » Thu Oct 12, 2006 11:53 pm
Nice to see you got it on, did you change the spring? If so have you noticed a bird like whistle with regular driving and lighter sneezing with aggressive driving? Appears your not running the extension hose supplied by turbosmart onto the nipple, are you having any leak issues?
Hopefully, your throttle responce has improved......
Previous
04' MX5 SE.
02' MX5 Classic ed.
floda
Postby floda » Fri Oct 13, 2006 3:19 am
Emma Chissit ??
I had looked at these and thought you couldn't turn an atmospheric BOV into a non vented unit.
Where do you run the return from, how and where to ?
ASE05
Re: Me new BOV
Postby ASE05 » Fri Oct 13, 2006 10:49 pm
blackster wrote:Nice to see you got it on, did you change the spring? If so have you noticed a bird like whistle with regular driving and lighter sneezing with aggressive driving? Appears your not running the extension hose supplied by turbosmart onto the nipple, are you having any leak issues?
1. Nuh, haven't changed the spring yet, off to the place of purchase in the mornin' to sort that one!
2. Haven't really experienced any whistle but it does make a pfshhhhht sound at almost any revs above 2.5k but that's not too my liking and will change as soon as I get time to spend in the garage.
3. Haven't fixed my nipple yet :mrgreen: but I'm not experiencing any major idle issues. It does seem to struggle occasionaly with returning to idle from high revs but nothing major. I reckon the stiffer spring should be the fix for that 8)
Floda: the bov has a a return that hooks up to the standard stuff whislt also having a partial vent to atmo. It's there for wank factor an not much more. You can however stop the atmo venting with a cap they supply. No more pfshhhhht 8)
blackster
Re: Me new BOV
Postby blackster » Sat Oct 14, 2006 12:39 am
With the new spring there will no pfssshhht at 2.5k only a birdlike whistle, you only get a lighter sneeze if 5k and thats with aggressive driving.
Stiffer spring will fix idle issue, just noticed you have a non standard vacuum hose, perhaps you wont need to add the extra bit, what i found the longer the hose the more time it takes the bov to react.
My understanding is that the cap is for blocking off the return hose, it doesnt block the trumpet, if you block the return hose, the bov will come fully atmospheric being louder and your more then likely gonna have issues with backfiring, splutering on re-exeleration and poor idle as no air is returning back to the intake and hence not being read by the AFM. The dual port was specifically designed to avoid AFM issues that were related with full atmospheric BOVS as its semi plumback.
If you want no noise whats so ever, you will need the plumback model.
FG-BOV-KTPB20 (20mm outlet)
http://www.turbosmart.com.au/index.php?id=44
Previous
04' MX5 SE.
02' MX5 Classic ed.
ASE05
Postby ASE05 » Sat Oct 14, 2006 9:02 am
Blackster: the trumpet screws off and the cap goes in it's place.....no more ricey pfssshhhhht 8)
blackster
Postby blackster » Sat Oct 14, 2006 9:47 am
ASE05 wrote:Blackster: the trumpet screws off and the cap goes in it's place.....no more ricey pfssshhhhht 8)
Are you sure? It looks like one peice, doesnt seem to budge clockwise or anticlockwise and not game to use a tool to have a go it.
The instructions say that the blank/cap is for supersonic full atmospheric BOV
I think once you put the new spring in your mind might change about the nature of the noise, it doesnt sound at all like wrx ricer!
Previous
04' MX5 SE.
02' MX5 Classic ed.
