Switch Assy replacement
Yoshi
Postby Yoshi » Sat Oct 07, 2006 1:27 pm
The part with the indicator switch, lights etc... Anyone replaced one of these? Gout a rough guide at how to get to it and replace it? Thanks.
1990 NA6
CT
Postby CT » Wed Oct 11, 2006 5:52 pm
You will have to remove the sterring wheel and the plastic shrouds around the steering column. Then it's a pretty simple procedure from memory. Make sure you get the signal cancelling mechanism oriented the same way as the original unit otherwise your indicators might not cancel when you want them to. 8)
Users browsing this forum: Bing [Bot] and 3 guests
