Sub and Amp affecting fuel economy??
Posted: Fri Oct 06, 2006 6:25 pm
This is a strange one. But a while back I did a lot of work on my MX over a weekend. Then after a while I started getting bad fuel economy. I know fuel guages are only a guide, but the way I look at it is that the guage will react the same each time. that is it might say 1/2 full but in reality be 2/3rds full, but it will do it consistently.
Anyway, after I had the 1.8 upgrade, I was still getting 400+ K's per tank full around town driving. I live in Canberra where most roads are 80kph except around housing areas. But I live very close to one of the main highways in Canberra so drive 60kph for about 1/2 a kilometre and it is 10 minutes of constant 80kph right to my work carpark at the AIS. Which is great.
OK, after all the work I did, which included installing a second amp and 6 inch bazooka tube subwoofer, spark plug change, oil change, cleaning the throttle body, after my next tank full of fuel, my total range dropped to 275k's per tank. Not happy.
So, a few days ago I took the sub out and the extra amp, which I mounted together on a MDF board so that it can be taken out as one unit. Since then I have been getting much better fuel economy like it was a month or 2 ago before I installed the sub.
Is it possible that the second amp and sub were drawing too much current away from the coils and hence not getting a decent fuel burn in the engine? The battery is a pretty decent and expensive gel cell sealed battery and the alternator is also working fine. It's not like the sub and amp weighed lots, not much really, so I didn't think it would be a weight issue.
Any ideas anyone?
Any ideas anyone?
