Clutch issues - ARRRRGGGHHH!!!!!!!
Uncle Arthur
Dodgy Award Benefactor
Postby Uncle Arthur » Mon Oct 02, 2006 11:44 am
Well - seems I spoke too soon.
Still having issues getting my clutch set up and working right. :evil:
I resealed the master cylinder on the weekend, but the pickup point is still r-i-g-h-t at the bottom of the pedal travel, and after trying to adjust that last night, now it seems my slave cylinder might be slipping, although it is showing no signs of leaking. :|
How little 'free' pedal travel should there generally be before you can feel the hydraulic pressure in the clutch pedal? Is it bad to have it there straight away or might this result in there always being a bit of pressure on the clutch arm? The last thing I want is for it to be effectively 'riding' even when my foot is off the clutch, or for there to not be the proper clamping pressure so it slips.
lowmiata
Postby lowmiata » Mon Oct 02, 2006 12:52 pm
sounds exactly like the same problem that paul had when he did his clutch
cant remember how he fixed it though it did go on for some time before it was fixed.
EVI15 1998 to 2008
jules
Guitar Hero
Postby jules » Mon Oct 02, 2006 1:59 pm
I don't see how the slave could slip. It either has air in the system or it moves as far as the Master dictates?
Is the system air free?
I would think about 10mm travel.
Jules
sabretooth
Postby sabretooth » Mon Oct 02, 2006 3:01 pm
Ahh, I take it you got the master rebuild kit fine then.
I've probably got about 10-15mm of travel in the pedal before it starts pushing on the master.
When you push on the pedal, how long is it before you feel any significant resistance?
If you push on the pedal slowly with light pressure, does the pedal slowly sink to the ground?
Did you do anything different to what I did when rebuilding the master?
You'll need an assistant for this, but how much pedal travel is it until you see the slave cylinder pushing on the pivot arm?
Also, Paul's clutch is still a little rooted. I had a drive of it a couple of months back and it's a prick to change gears with.
jules
Guitar Hero
Postby jules » Mon Oct 02, 2006 3:07 pm
\"Sometimes\"......after the flywheel is machined you can get this problem. It is caused by too much wear on the flywheel causing the clutch to be unable to operate correctly.
I remember a Laser we did a clutch on and the problem occured. The boss at the time made me put a flat washer between the pressure plate and the flywheel on each bolt. It fixed it, but I don't know at what cost.
Jules
Uncle Arthur
Postby Uncle Arthur » Mon Oct 02, 2006 4:01 pm
sabretooth wrote:Ahh, I take it you got the master rebuild kit fine then.
I follwed the Sabretooth guide exactly - I set it up last night adjusting the piston travel and pushing on it by hand so that I could feel the piston start to act against the master cylinder with as little travel as possible.
It ended up though that the clutch wasn't disengaging properly at all - getting a minute amount of slip, hence my thoughts that the slave (previously resealed) might also be leaking a bit. $36 for a replacement slave (from Mania if they ever answer the phone) might be the best option for my next step - I have a reseal kit for the slave, but might save it a go reconditioned.....
jules
Guitar Hero
Postby jules » Mon Oct 02, 2006 4:04 pm
Arthur,
A rebuild will ony take an hour. I'd do that first and see how you go?
or try MX5Plus for an old one to test.
Jules
Uncle Arthur
Postby Uncle Arthur » Mon Oct 02, 2006 4:16 pm
jules wrote:Arthur,
Jules
Yeah - I know - I've got the rebuild kit - just that I've done it once so I was wondering about the effectiveness of a second time. Might investigate how much to get it resleved.....
jules
Guitar Hero
Postby jules » Mon Oct 02, 2006 4:29 pm
Oh, so you've already done the slave rebuild. I thought you had only done the master.
Jules
Uncle Arthur
Postby Uncle Arthur » Mon Oct 02, 2006 4:35 pm
jules wrote:Oh, so you've already done the slave rebuild. I thought you had only done the master.
Jules
I rebuilt the slave once before - about 2 and a half years ago..... I checked it on the weekend when I did the master slave rebuild and it didn't look to be leaking.....
jules
Guitar Hero
Postby jules » Mon Oct 02, 2006 4:41 pm
Well unless it's jammed in there (which you could diagnose faily easily), there shouldn't be a leak without fluid loss.
Is it jammed? If it isn't then I would still lean towards air?
Jules
Uncle Arthur
Postby Uncle Arthur » Mon Oct 02, 2006 4:45 pm
jules wrote:Well unless it's jammed in there (which you could diagnose faily easily), there shouldn't be a leak without fluid loss.
Jules
There shouldn't be air in it as I bled it slowly and thoroughly on the weekend - I'll do the slave reseal, rebleed and go from there..... :(
jules
Guitar Hero
Postby jules » Mon Oct 02, 2006 4:48 pm
Can you get Jen to do the pedal work whilst you bleed?
Jules
CT
Postby CT » Mon Oct 02, 2006 4:52 pm
Public Holiday in NSW today........... 8)
jules
Guitar Hero
Postby jules » Mon Oct 02, 2006 4:58 pm
That's nice Chris.
Jules
