80kw atw on Mania Dyno!
Mania have their dyno running and my NA8 apparently has 80kws! The dyno has replicated several power figures from other dynos which are reputed to be accurate so I am confident this figure is also accurate. Given the only modification to my car is a Mania CAI I think 80kws is very good. I think standard is about 70-72 kws so either my engine is a freak or the Mania CAI is a very worthwhile mod.
Dan
PS
Thanks again for your efforts today David, Daniel, Andre and Simone.... you guys are tops!
Dan
PS
- nath
- Mr_Q
Springs are great thanks Mr Q, they must work better after the second installation...
I am happy with the compromise as they seem to match the shocks quite well with a controlled but not crashy ride. The cornering is sharper however I think they may get a little choppy with mid corner bumps.
Yeah that was me getting the BD installed Nath. I was also trying to get my second hand konis installed however we had a few dramas as they were actually to suit a NB and made the car look like a Landcruiser (there was almost 10cm between the guard and rear tyre!). Are you the guy who is doing the turbo, the guy who bought the radiator, or the guy who was having the heater hoses done
My car has no engine mods besides the CAI. The timing is standard and the plugs and leads are at least 3 years old!
Dan
Dan
- irwin83r
Spranga wrote:Springs are great thanks Mr Q, they must work better after the second installation...I am happy with the compromise as they seem to match the shocks quite well with a controlled but not crashy ride. The cornering is sharper however I think they may get a little choppy with mid corner bumps.
Yeah that was me getting the BD installed Nath. I was also trying to get my second hand konis installed however we had a few dramas as they were actually to suit a NB and made the car look like a Landcruiser (there was almost 10cm between the guard and rear tyre!). Are you the guy who is doing the turbo, the guy who bought the radiator, or the guy who was having the heater hoses done![]()
Dan
so the car sits alot lower with the standard shocks hey? is good to hear. lower than standard now or just about the same?
irwin83r wrote:Spranga wrote:Springs are great thanks Mr Q, they must work better after the second installation...I am happy with the compromise as they seem to match the shocks quite well with a controlled but not crashy ride. The cornering is sharper however I think they may get a little choppy with mid corner bumps.
Dan
Lower than standard about the same as most NA koni/king combinations. How your beast running? No more burping I hope.
- irwin83r
Spranga wrote:Lower than standard about the same as most NA koni/king combinations. How your beast running? No more burping I hope.
thats good. looked a tad wierd on the other shocks
yeah car hasnt missed a beat since but im starting to get the HP itch again
Spranga wrote:...My car has no engine mods besides the CAI. The timing is standard and the plugs and leads are at least 3 years old! ...
Exhaust is stock too?
- Fuzzlet
Spranga wrote:Exhaust is stock![]()
You would have to ask Mr Q what it cost to have a run on the dyno. David wanted to put mine on the dyno just to see what numbers it would come up with, so there was no charge. The dyno is a new toy for David and Daniel so give them a call and I am sure they will look after you!
To give you an idea of cost, its gonna cost me about $1835 to use their dyno.....but thats also including new ECU.....and waaaaah pssst
- rodent
- 강남 스타일
Fuzzlet wrote:Spranga wrote:Exhaust is stock![]()
Wait - your tarrrbo install's costing you under $2k??
- Sean
rodent wrote:Fuzzlet wrote:Spranga wrote:Exhaust is stock![]()
I was thinking - Damn that's cheap!
- bigdog
- King of the kennel
