SP motorsport on my SE (updated Dyno pics)
blackster
Postby blackster » Tue Sep 26, 2006 8:44 pm
3inch dump pipe, high flow cat, into 2.5inch stainless steel muffler, nice mandrel bends with no slag.
Had it done today, feels less restricted and turbo appears to spool up quicker, noticing boost starting at around 2500rpm.
Its a 4th gear power run, it was about 28 degree's today not much less in the booth.
Appears to gain 1 pound of boost intially then drops back a little, runs a little rich at top end, 113rwkw is not a bad, i was expecting a little bit more. I guess the larger intercooler and SP air induction makes a big difference if the 132rwkw is the true net gain, im still skeptical. The addition of a haltec piggyback, can lean out the top end running rich which would net 7rwkw extra.
Previous
04' MX5 SE.
02' MX5 Classic ed.
Craig
Postby Craig » Tue Sep 26, 2006 9:08 pm
Where's the rest of the SP Motorsports kit? :P
blackster
Postby blackster » Tue Sep 26, 2006 9:25 pm
Craig wrote:Where's the rest of the SP Motorsports kit? :P
Are you refering to this :D
The car above had some oil leaking from one of the fabricated pipes, noticed when the car was making only 112rwkw on a previous dyno run.
When im not so poor, it will be comming. I think i might be able to fabricate it myself for a bit cheaper.
Previous
04' MX5 SE.
02' MX5 Classic ed.
Craig
Postby Craig » Tue Sep 26, 2006 9:32 pm
blackster wrote:When im not so poor, it will be comming
Just dont eat for a month, or pimp yourself! :lol: :shock:
blackster
Postby blackster » Tue Sep 26, 2006 9:40 pm
Not eating for a month would probably equal 30kg loss, not that im heavy to begin with. 30kg weight reduction would probably mean id be quicker without the rest of the SP motorsport kit :lol:
As for pimping, i guess the extra sex would do great for adding further weight loss. :mrgreen:
Previous
04' MX5 SE.
02' MX5 Classic ed.
Craig
Postby Craig » Tue Sep 26, 2006 9:45 pm
Sounds like a win win situation then! :mrgreen: I'd love a huffer on my humper! :shock: :mrgreen:
bigdog
King of the kennel
Postby bigdog » Tue Sep 26, 2006 11:03 pm
Craig wrote:I'd love a huffer on my humper! :shock: :mrgreen:
:mrgreen: And who wouldn't! :P :roll: :shock:
Craig
Postby Craig » Wed Sep 27, 2006 12:37 am
Or if it was a V8 it'd have a 650 double humper! :lol: :shock:
ASE05
Postby ASE05 » Wed Sep 27, 2006 10:11 pm
Looks good.
Excellent another SE being played with :lol:
Sing that song, puff all night long.......
blackster
Postby blackster » Thu Sep 28, 2006 6:04 pm
C+C wrote:Hi there blackster
1.did you get the kit from mania?
2.did you get the whole kit at once or in stages?
3.how much was the exhaust (plus fitted)?
4.is the exhaust from the tubo back?
5.any other options with the exhaust, such different type of cat, or different diameter?
6.whats the diff btw mania's and SMP's?
sorry for the thousand questions!!!
cheers
C+C
1.Yes
2. No, one stage at time, although i think i can fabricate the rest for a bit cheaper myself.
3. Depends on your negotiating skills
4. Yes
5. I guess yes, because there was talk of 3inch system all the way back, but it requires the computer to be changed.
6. Not sure, havent seen SMP's
Previous
04' MX5 SE.
02' MX5 Classic ed.
Sean
Postby Sean » Thu Sep 28, 2006 7:10 pm
On teh Dyno sheets you've bloked out the ID, but left the file name which may also give away the car in question to anyone you didn't want to see the ID 8)
blackster
Postby blackster » Thu Sep 28, 2006 7:20 pm
Sean wrote:On teh Dyno sheets you've bloked out the ID, but left the file name which may also give away the car in question to anyone you didn't want to see the ID 8)
Thanks, its been edited
Previous
04' MX5 SE.
02' MX5 Classic ed.
kula
Postby kula » Fri Sep 29, 2006 1:09 am
hmmm
113rwkw?
thats about 20 less than it should be right?
Garry
Postby Garry » Fri Sep 29, 2006 10:03 am
It doesn't have any intake mods yet kula.
So that would be about 5rwkw extra from the exhaust? Another 20ish rwkw from CAI and intercooler. Interseting.
blackster
Postby blackster » Fri Sep 29, 2006 5:30 pm
THE REAL BORIS wrote:It's a lovely looking system. What was the "before" dyno. figure?
The dyno at the place I was doing the exhaust wasnt working, so I was unable to get it dynoed pre exhaust. SE's (stock) that have been dynoed at C&V doing a power run on a dynodynamics meter were doing anything from 97-102rwkw according to the owner.
Previous
04' MX5 SE.
02' MX5 Classic ed.
