Air flow kit???
JSE
Postby JSE » Sat Sep 23, 2006 11:39 am
If you wana beef it up definately do a cold air intake system and replace the exhaust/cat system. These two mods will get your MX feeling alot more free. Throttle response will be much more tight and accurate and it won't feel like a slug anymore.
All they are doing is making it easy for the engine to suck and spit out as much air/waste as possible. Imagine yourself trying to breathe through a straw compared to breathing through a piece of 3inch PVC piping. I hope that all makes sense :?
****I was dissappointed with the amount of power from the 1.6 as well :evil: when I bought mine.
Matty
Postby Matty » Sat Sep 23, 2006 11:56 pm
Hey Mikey. Be aware that an intake/exhaust kind of setup won' tbe massively faster than a standard car. You'll have maybe 10-15% more power, focussed on the top end.
minimum costs:
DIY cold air intake ~$150
mild steel cat-back exhaust ~$500
used extractors ~$300
from there, start adding bigger bucks for smaller gains.
rodent
강남 스타일
Postby rodent » Sun Sep 24, 2006 12:05 am
Mikey do you have a link to that intake kit on eBay?
nath
Postby nath » Sun Sep 24, 2006 11:40 am
Also advance your timing to 14 degrees.
And don't shift at anything under 4000 rpm
:mrgreen:
Matty
Postby Matty » Sun Sep 24, 2006 3:42 pm
mikey mx5 wrote:My car is only a 1.6L, and I don't how to construct anything myself! I can change the water and oil and that's it!
Mikey
Join the Vic club, come to some events, make some friends, and you might find someone who will help you out...
Matty
Postby Matty » Sun Sep 24, 2006 3:53 pm
we have a monthly run, about 10 motorsport events a year, driver training, christmad party, AGM, plus all sort of other stuff. usually about 40 events a year!
We love MX-5s just as much as you do!
see the club website. www.mx5vic.org.au
Postby Okibi » Sun Sep 24, 2006 11:48 pm
Join the club for sure, great bunch of people and the good advice /contacts will save you a fortune and heartache.
Andrew
Postby Andrew » Mon Sep 25, 2006 12:05 am
mikey mx5 wrote:OK, so does the Vic club still have weekly events, or just the big events on the calendar?
Not club related but is a weekly MX-5 event - link
