why is a 99 model head better than others....?
marky210
Postby marky210 » Tue Sep 19, 2006 10:50 am
Ive been hearing and reading alot that the Head off a 99 model mx5 seams to be really good and i was just wondering what makes it so good compared to the other models :?:
Mark :D
StanTheMan
Postby StanTheMan » Tue Sep 19, 2006 10:52 am
not nececarily better. But had no niggling issues. one of the few rock solid models.
Garry
Postby Garry » Tue Sep 19, 2006 10:56 am
The NB head flows better than the NA8 head and the 98/99 doesn't need to worry about VVT hardware so it would be easier to retrofit to an NA. Thats my guess.
marky210
Postby marky210 » Tue Sep 19, 2006 11:02 am
Awsome :D
Thanks for that Stan the man
and thanks Garry :D
Just want to learn as much as i can about these awsome cars :P
Mark 8)
Matty
Postby Matty » Tue Sep 19, 2006 12:02 pm
Apart from the better head flow (which is the main reason it's better than the NA8 head), the NB uses solid lifters (so the cam profile can be more aggressive and rev higher), and the intake has dual runners for better high and low speed power.
more here: http://members.aol.com/solomiata/MX5Engine.html
CT
Postby CT » Tue Sep 19, 2006 2:30 pm
Definitely the most important aspect is that the 98+ head has a different angle on the inlet tract which flows better than the earlier head. It has solid lifters as a bonus. The manifolds do not matchup. Exhaust however is mildly different but the bolt pattern is the same.
sirbob
Postby sirbob » Tue Sep 19, 2006 9:23 pm
Does that mean an NB set of extractors will not fit an NA??
Now driving a Grand Vitara whilst waiting for the elusive Black SE
irwin83r
Postby irwin83r » Fri Sep 22, 2006 9:15 pm
sirbob wrote:Does that mean an NB set of extractors will not fit an NA??
pretty sure they still will. just where it meets the CAT will be different, still use the same manifold patterns im pretty sure.
Garry
Postby Garry » Sun Sep 24, 2006 10:45 am
Do they? I thought the ports were slightly different. Maybe I'm getting confused with the intake.
