idea for turbo manifold
Fatty
Postby Fatty » Thu Sep 07, 2006 8:52 pm
so this is my current exhaust manifold.
so i was wonderring, can i just get a turbo flange , cut the bottom of the pipes as below ( see where i've put a line thru where i'd cut it), then whack the flange on and weld her up?
so just convert my current manifold to a turbo manifold?
is this possible? i have some ideas as to why this might not work, but thought it was worth asking .
Boags
Postby Boags » Fri Sep 08, 2006 10:52 am
The idea is sound and has been done before on other engines. However, I don't think it will work on the MX5 because of the lack of space.
You have a PM Fatty.
Boags
Fatty
Postby Fatty » Fri Sep 08, 2006 11:52 am
hey boags, replied to yr pm. hope you got it, things are sllooooowwww around here at the moment.
Boags
Postby Boags » Fri Sep 08, 2006 12:14 pm
Right back at you... 8)
