Intercooler - size / placement / fitting ????
tasroadster
Postby tasroadster » Tue Sep 05, 2006 2:20 pm
Just wanting some info on Intercooler sizing for a NA6.
Also, the fitting and placement etc. maybe even plumbing ??
Where do the factory place theirs ? And their specs ?
Thanks for your help.
Regards.
Garry
Postby Garry » Tue Sep 05, 2006 2:42 pm
The factory never produced an NA 1.6 turbo. In the UK the UK Mazda distributer did something similar to the Australian SP with an NA6 except that it was all done outside of Mazda and sold as a kit that could be fiited to new cars and retrofitted to used cars. I'm not sure if it even had an intercooler. Were intercoolers as popular in the early 90's as they are now?
Russellb
RIP Nov 2014
Postby Russellb » Tue Sep 05, 2006 3:01 pm
Intercooler are best placed infront of the Radiator
As for there Size on the NA with out A/C you can fit a 650mm x350mm core in there with out to much hassle.
This is the core I put in my Old mans car
It was an Ebay jobbie and on the Dyno with 5PSI the intake temps were down around the low 20's
I have Kept the A/C but had to remake every bit of pipr work
My ClubmanRebuild
MX5 SE Rally car is HERE :)
Juffa
Postby Juffa » Tue Sep 05, 2006 3:21 pm
I have a massive intercooler in my NA, with air cond. Not sure of the exact size. Basically mounted in the same place as Russellb. Not too many places to mount an intercooler in an MX-5 unless you do major mods to the front end.
J
Juffa
Postby Juffa » Tue Sep 05, 2006 3:27 pm
There is a Vic club member (JohnD)with that kit in his Neo NA. I'm pretty sure there is no intercooler. The Melbourne based turbo shop that fitted Johns still has one of these kits for sale. $3500 for the kit + $1500 to fit it. It uses the standard ECU, with a piggy back. Nice looking kit, very well made as you would expect given it was sold in the UK with full warranty.
J
lowmiata
Postby lowmiata » Tue Sep 05, 2006 7:51 pm
thats how mine was done much the same as the others
hard to really do it any other way and it still fit neatly!
EVI15 1998 to 2008
Sean
Postby Sean » Tue Sep 05, 2006 9:41 pm
damn that's a clean engine!
Russellb
RIP Nov 2014
Postby Russellb » Tue Sep 05, 2006 10:08 pm
It would want to be it hadn't even been Filled with oil at that stage :)
My ClubmanRebuild
Matty
Postby Matty » Tue Sep 05, 2006 10:20 pm
Juffa wrote:There is a Vic club member (JohnD)with that kit in his Neo NA. I'm pretty sure there is no intercooler. The Melbourne based turbo shop that fitted Johns still has one of these kits for sale. $3500 for the kit + $1500 to fit it. It uses the standard ECU, with a piggy back. Nice looking kit, very well made as you would expect given it was sold in the UK with full warranty.
J
I believe the BBR kit came with an intercooler, but it was a tiny jobbie (smaller than the SE's) and mounted behind the radiator...
sabretooth
Postby sabretooth » Tue Sep 05, 2006 11:10 pm
Moggy
Postby Moggy » Wed Sep 06, 2006 9:19 am
My intercooler is 500x200x70 and sits pretty much where everyone else's does. This size slid up between the front chassis rails perfectly with a couple of millimetres each side. $240 off ebay...
What turbo are you running russellb? Because that intercooler is massive! I would expect to see it bolted up to a T78 or a T51R or suchlike. Any idea what the pressure drops for it are? By the way, like Sean said, that is the cleanest engine I've ever seen! Wish mine looked like that...
sabretooth
Postby sabretooth » Wed Sep 06, 2006 10:07 am
Do you other intercooled folk still run your AC?
mx52nv
Purple Porsche Eater
Postby mx52nv » Wed Sep 06, 2006 10:52 am
I do
Fatty
Postby Fatty » Wed Sep 06, 2006 11:36 am
hey guys, do you reckon 550 x 140 x 65 with 2.25 inch pipes is big enough ? i won't be running massive boost, probably 7 or 8 psi max.
sabretooth
Postby sabretooth » Wed Sep 06, 2006 2:03 pm
That'll do nicely.
