Assorted exhaust questions...
Boags
Postby Boags » Mon Sep 04, 2006 11:23 pm
Howdy all,
I am upgrading my exhaust system, and have a few questions. It will be cat-back for now.
It is about time the cat was changed so I will definately go 'new' for that, but my muffler is only 3 months old and has 2\" inlet and outlet holes.
Is there any point making the pipes larger if the exhaust gas is going to have to squeeze through a 2\" hole in the muffler?
Is 2.25\" sufficient for a cat-back system for a turbo 1.6(not yet, but will be) or should i go 2.5\"? Price isn't all that different, it's only about $50ish cheaper to go the 2.25.
Thanks in advance.
Boags
kula
Postby kula » Mon Sep 04, 2006 11:31 pm
the bigger the better for a turbo..
NA 1.6 id go 2.25,
turbo, id even think about 3inch.
Boags
Postby Boags » Mon Sep 04, 2006 11:55 pm
Thanks kula!
Am I up for a new muffler aswell?? :?
Also, there is a sausage shaped \"thing\" after the cat and before the muffler, what does it do and do I need one?
Thanks again.
Boags
JSE
Postby JSE » Tue Sep 05, 2006 12:59 am
Resantor?
kula
Postby kula » Tue Sep 05, 2006 9:30 am
yeah u might need a new muffler, depending on what it is..
but a good exhaust shop will tell u that..
it is either a flex joint or resonator (another muffler)
Boags
Postby Boags » Tue Sep 05, 2006 10:11 am
Yep, it must be the resonator, it's not a flex joint. How crucial are they? I spose as long as the muffler is good and not loud, it shouldn't be necessary.
Boags
Moggy
Postby Moggy » Tue Sep 05, 2006 11:48 am
I got my exhaust, which is 2.5\" on a 1.8 turbo, done at Exotic Exhausts in Sumner Park. They seemed a bit dodgy at first but I was very impressed with their work, especially the way they ran the exhaust from the left side to the barrel muffler on the right side with minimal bends. They're relatively cheap and do whatever you ask as well...
sirbob
Postby sirbob » Tue Sep 05, 2006 12:03 pm
Pop into CES one saturday, Trevor will tell you exactly what you need!
You seriously need to consider the noise vs. diamter characteristics of the pipe as well..
As Butters said, i am running a 2.25' straight through, (No resonator) with a 3\" muffler and 4\" tip... It sounds frigging awesome when your up it, and will shut up nicely when your just putting around, however, there is no quite way you can drive up a hill... (ie, when the motor is under any significant load, the exhaust becomes fairly loud)
As such, i would reccomend 2.25\" as a good middle ground... Will make you non-turbo NA rev very nicely, but should shut up when you want it to as well..
I think 3\" is way to big, and will sound like a fart in a bottle for most of the time, think about how many skylines have crappy notes through their 3\" full exhausts and they're pushing 2.5L of airflow compared to your 1.6L... (Also consider that a 3\" system will sit considerably lower than your chassis rails and will hence bottom out more often than a smaller diameter)
I also have heard that 2.5\" is a good diameter for turbo MX5's, and if you get a good neat and straight exhaust (Like CES) then you will get a good clean airflow far greater than the \"Bodgey Brothers Racing Pipes\" 3\" \"Sonic Boomerator\" exhuast system...
When i get home I will post some pictures i took last week of my exhaust so you can see what i mean...
Now driving a Grand Vitara whilst waiting for the elusive Black SE
adamjp
Postby adamjp » Wed Sep 06, 2006 7:03 pm
Some have seen this before, it is a repost of some words I wrote a couple of years back, with some cleaning up for readability.
First some definitions:
NA Naturally Aspirated
FI Forced Induction
If you have extractors (tuned length headers) then you are attempting to 'pull' the exhausted gasses out of the combustion chamber with pulse tuning (harmonics). These match with the tuned length intake manifold to set up a resonance within the combustion chamber that has the air charges moving in well ordered packets (at least that is the theory).
Remember we are talking about gasses here. For any given diameter of pipe the gas will flow at a given speed. If the pressure is constant, yet the diameter is reduced, the speed will increase. Increase the diameter, and the speed will reduce. Unlike liquids, gas WILL locally compact (increase pressure), causing pulsation in the system. It is this pulsation that we try to use to ‘tune’ the engine by using the high and low pressure components of the pulse. The aim is to get more air into an engine. The measure of air in / air out is referred to as volumetric efficiency (VE). It is possible to increase the size of the intake charge beyond that of the empty cylinder - a very good thing. Engines with this capability have a VE exceeding 1, meaning they get the advantages of forced induction without the disadvantages. B6/BP in a NA MX5 probably works at a VE of around 0.8. Most performance modifications to an engine are about getting the biggest packet of air into and out of the engine as quickly as possible.
People often equate low backpressure in exhaust systems (due to large pipes) with loss of power. What they are actually observing is a loss of gas velocity at low RPM due to large pipes. Without the velocity, you get the pressure pulses stalling and diluting with a consequent loss of beneficial harmonics and VE. It starts to come back at higher RPM as the engine passes more gas. The optimum outcome of all of this is that the gas comes out of the exhaust port travelling really fast, moves into the exhasut system and tries to keep the speed up as it cools, contracts and meets other exhaust gases from other pistons. Your engine can only move so much gas, and the trick is to tune the exhaust system to keep gas velocity UP in the operating band you desire. You can go too big, and some will tell you ‘you must have some backpressure’.
The concept of backpressure on an NA car was originally to keep some of the exhaust gases lingering around the exhaust port to stop the incoming charge sweeping straight through the combustion chamber. This will happen with cams that have overlap. The lack of backpressure would substantially increase the fuel costs (as the fuel is not being burned in the combustion chamber, but in the exhaust system and is therefore wasted) and will raise the temperature of the exhaust system (leading to early failure). Afterburning is not applicable to piston engines.....ever.
Performance NA camshafts usually increase overlap (inlet and exhaust open at the same time) to produce increased filling and consequent scavenging of exhaust gasses. I won't go into valve angles, but this also has an effect. This all applied in the old and bold days of pushrod V8s and holley carbies. Lumpy idle (mucho overlap cam) and single plane intake manifolds developed good power high in the range, but were only saved down low by the sheer displacement of the engine generating torque. Keeping backpressure on common cars (not the performance GT types) allowed low range operation without using prodigious amounts of fuel. It impacted high range operation too by reducing flow when it really was needed (but the ol’ station wagon still went well enough).
Keep one thing in mind: Backpressure is the enemy of VE by reducing the amount of waste air that can be discarded.
Adam
irwin83r
Postby irwin83r » Wed Sep 06, 2006 7:24 pm
another vote for not leaving out the resonator.
will drone and sound like a bee in a tin.
adamjp
Postby adamjp » Wed Sep 06, 2006 7:35 pm
The common thing that you will hear from the turbo guys is
'I put this sik dump pipe on, and now the turbo spools up quicker.'
They are kinda right.
Bigger dump pipe = lower pressure area immediately after the turbine. Lower pressure area increases the velocity of the gasses through the turbine, thereby increasing possibility for the rate of change or acceleration of the gas flow. This gives the turbo the ability to accelerate faster. There is a limit to this from a tuning point of view, and a practical size consideration as well. The rally guys also utilise both blow off valves and if they can afford the maintenance, anti-lag, to keep the turbo spooling when they are off throttle. Anti-lag is hell on turbines however (this IS afterburning for piston engines).
A major thing that the duff-duff boys forget with their ever increasing exhaust sizes, their gas velocity is dropping. A turbo does not work on the pressure differential between the combustion chamber and the exhaust system. It works because of the mass of the gas flowing through the turbine as it moves from the combustion chamber (high pressure) to the exhaust (low pressure). It is possible to get some pulse tuning happening here too. Turbo extractors are a good thing, they are the bunch of twisted pipes you sometimes see that connect the exhaust port with the turbine.
Note that the concept of scavenging has only small application AFT of the turbine. The turbine provides so much backpressure on the engine that harmonics induced by the 4 stroke process are largely cancelled out. If the gas then stalls in the exhaust system due to inadequate velocity (caused by a 4\" pipe on a 2000cc engine) then you are going to lose responsiveness and power across most of the range. Where the duff-duff crowd go wrong is the ASSumption that large size is necessary for the remainder of the system. Good exhausts have a larger dump pipe straight off the turbo, but by the time the CAT comes into play, the exhaust is reducing to a smaller diameter. A CAT is also a resonator, and it slows the gasses, and by absorbing heat from them, causes them to contract.
For a race car which operates at high RPM most of the time (nods to Sabre, CT and Matty) you need a bigger exhaust to keep the backpressure down due to the increased volume of air passing through. Of course, you have fitted cams, injectors, timing systems and inlet modifications to optimise this operating range, and VE at that range.
Street cars generally don't have to operate at constant high-rpm. This is one reason the car companies are starting to build turbochargers with variable flow characteristics (by vanes directing the airflow onto the turbine). The idea is to increase responsiveness when flow volumes are low, but not inhibit them when they are high.
No accounting for style and decibel induced power however.
Factories build exhaust systems which must conform to the laws of the land, laws of physical fitment, and the laws of cost effective manufacture. Can they be improved on? Hell yes! Do you need 4” fully sik all the way back? Hell no! It is possible to have an exhaust system that is quiet, high flow and power increasing.
An ideal exhaust system would be small at low RPM, but grow to larger diameters as the RPM increases. If you watch the exhaust of a jet engine, you will see it has a variable nozzle for this very reason (they have variable intakes too). As backpressure is the enemy of VE, this would maximise VE at any point in the RPM range. Trouble is there is not any commercially available technology that does this for piston engines. Due to the wide operating range of a car engine, you will have backpressure somewhere in the higher range in order to retain gas flow in the lower range. Like any other part of the engine, you tune the exhaust to suit the operating band desired, and since we cannot change our exhaust sizes as required, you have to choose one size.
Adam
adamjp
Postby adamjp » Wed Sep 06, 2006 7:41 pm
So the accepted wisdom of 2\" for the 1.6 is largely (and empirically) correct. The key is to get the spent gasses out of the way quickly. 2.25\" is probably good for the 1.8, but may actually be a little large. For turbo engines, you will need bigger, but 3” is probably too big, I would suggest 2.5” for most MX5 turbo engines would be a good place to be.
As an aside, the sound from an exhaust will have a lower note (do reh mi) with a larger exhaust as the gasses are leaving the tip at a lower velocity and pulse pressure. Higher speed pulses come from smaller pipes and these consequently produce higher pressure variations in the system and sharper sound. Louder comes from having less resonating chambers (which slow the gasses down and capture really intrusive audible harmonics). A catalytic converter, muffler and a resonator are resonating chambers. The pitch or 'note' of an exhaust is governed by the stroke, the extractor design and the orientation of the various resonating chambers in the exhaust system.
Adam
Boags
Postby Boags » Wed Sep 06, 2006 8:14 pm
Wow, thanks adamjp!
From what you have said, it would be a good idea for a 1.6 turbo to have 2.5\" dump/back pipe to the cat, and maybe a 2.25\" cat-back system? And noise is my enemy, so resonator and decent muffler are definately the go!
I am thinking that it will be worth waiting till after the turbo install to do the exhaust, that way, if I get stalled for some reason, I won't have an exhaust system that doesn't suit the car.
Thanks again for the info!
Boags 8)
adamjp
Postby adamjp » Wed Sep 06, 2006 8:19 pm
Like others have said, go talk to a good exhaust shop.
Despite the fact I have never been there, CES looks and sounds like a place that knows what it is doing. I spoke to them when i was searching for extractors for my car a couple of years back. That others commend them suggests you could do worse than go and talk to them.
Adam
sirbob
Postby sirbob » Wed Sep 13, 2006 10:32 pm
Here's my example of CES's workmanship... (posted eventually!!!!!!!)
Dont have one showing the extractors from the top... Not much to see there really... All in all i am a very happy customer...
