Cooling issues
Rob81w
Cooling issues
Postby Rob81w » Fri Sep 01, 2006 1:57 pm
G'dy all,
As the temperature increases, so does my temp guage.
As soon as i am in the slightest amount of traffic, it starts climbing, to the point were i have darted off down side streets to get some air blasting around it.
I have done all things, including, coolant, thermostate, water pump ect. The only thing i havent done is re con the radiator. i dont want to cough up $XX amount to find it makes no difference, the thermo's are working.
any other thoughts? oh, and its topped up with coolany and isnt losing any?
Cheers, Rob
Club # 1007
CT
Postby CT » Fri Sep 01, 2006 2:22 pm
Time for a recore Robbie! 8)
JBT
Postby JBT » Fri Sep 01, 2006 2:46 pm
Fan working?
A reconditioned radiator is not too expensive if it's just the top tank required. Top tank failure is common at that age.
Rob81w
arghhhh
Postby Rob81w » Fri Sep 01, 2006 3:38 pm
tHatnks all, time for some quotes i thinks!
Hows things CT?
Cheers, Rob
Club # 1007
Postby Okibi » Fri Sep 01, 2006 7:43 pm
Replaced the radiator cap?
sabretooth
Postby sabretooth » Fri Sep 01, 2006 10:29 pm
Does it only happen in stop-start traffic? Is it fine when driving at normal speed? If so, then your thermofan isn't turning on - and it's either the thermoswitch, or the fan itself.
Me
Postby Me » Fri Sep 01, 2006 10:47 pm
sabretooth wrote:Does it only happen in stop-start traffic? Is it fine when driving at normal speed?
my NA6 used to have the same problem. i though it was the fan. the water pump clogged a few weeks later. the problem disappeared when a new pump goes in. :roll:
CT
Re: arghhhh
Postby CT » Sat Sep 02, 2006 9:41 am
Rob81w wrote:tHatnks all, time for some quotes i thinks!
Hows things CT?
Good thanks mate - see my fellas out at Woonona - they did me a full recore (PWR HD) with brand new tanks for ~$400. Alternatively, try Mazda. They might suprise you. Boyracer also likes the ADRAD brass ones for ease of repair should you evern need it. Price is similar too. 8)
Matty
Postby Matty » Sat Sep 02, 2006 2:54 pm
been there, tried all the usuals. A new radiator fixed it.
Moggy
Postby Moggy » Mon Sep 04, 2006 8:07 am
I noticed Duj has a used radiator for sale for $40...
http://www.aus-cartalk.com/viewtopic.php?t=21078
