thanks
Removing the airfilter off a SE airbox
- blackster
Would any SE owner kindly share how they remove the airfilter out of the stock air box. Its not as straight foward as the N/A NB box. Feel free to edit the photo with arrows for easier explanation
thanks
thanks
Previous
04' MX5 SE.
02' MX5 Classic ed.
04' MX5 SE.
02' MX5 Classic ed.
- PT
You need to get access to all the clips, one on each corner, you need to be contorted and what not.
Try removing the little snorkel too.
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
- blackster
PT wrote:You need to get access to all the clips, one on each corner, you need to be contorted and what not.
The clips come off no problems which allows you to lift the top of the air box by about 2-3 cms, its that hose above to the left of o2 sensor as well as the hose going into the airbox that stops the top of the air box from fully being lifted.
Are you saying by removing the snorkel, you can get the filter out, or are you saying to remove it to get more induction noise/better flow?
Previous
04' MX5 SE.
02' MX5 Classic ed.
04' MX5 SE.
02' MX5 Classic ed.
- blackster
- jules
- Guitar Hero
