Posted: Sat Aug 19, 2006 6:36 pm
Are your injectors leaking down when you shut off the car, is that the issue?
Generally speaking, the way it works is that a mechanic will remove the injectors and then either send them to an injector shop for cleaning or a mobile van type of guy will come over to do it.
The cost is pretty std (IIRC about $120 for the injector guy), and I figure that pretty much any normal mechanic would be able to do it for about that much again in labour.
