HELP- Turbo-oil and coolant lines
rjr666
Postby rjr666 » Mon Aug 14, 2006 10:12 pm
where do i grab the oil and coolant from the block of a b6?
Ive seen pictures of oil outlet at the back of the plenum, but think I got told you can also get it from the side of the block as there are two plugs in the side...see attached pic.
Think its lower plug is coolant and oil at the top? :S cant remember
which is which and wat is better? block or the behind the plenum?
Also where should i tap in my coolant return too?
[/url]
I need a sponsor
Garry
Postby Garry » Tue Aug 15, 2006 9:53 am
When we did the turbo install on the Moneypit we copied the SP installation and sourced the oil from the rear exhaust side of the head and got the cooloant from the water bypass tube that runs from the thermostat housing to the water pump. Nothing has seized up or melted so I guess it's working OK.
Juffa
Postby Juffa » Tue Aug 15, 2006 11:41 am
The oil pickup point is the small, more oily plug, bottom right of the two in the photo for the 1.6l engine.
I used the existing water junction at the front of the block for the water pickup and drain.
I used the Fly'n Miata install instructions for the 1.6l engine.
J
sabretooth
Postby sabretooth » Tue Aug 15, 2006 12:33 pm
There's my fitting going into the side of my block for my turbo setup. The used one is the oil one (in agreeance with Juffa nad Garry).
With that there, I honestly struggle to understand why people go through the garbage of T-piecing the oil pressure sendor and running a long hose around.
Moggy
Postby Moggy » Tue Aug 15, 2006 4:20 pm
I used both of them for my setup. Bottom right is the oil pressure and top left is coolant pressure.
rjr666
Postby rjr666 » Tue Aug 15, 2006 7:56 pm
ok great great... Thanks
Now jus the last question i hope someone can help me.
Do they have a picture of where they put there Coolant REturn back in to the cooling system?
Is it possible just to tap in to one of the radiator hoses? Eg top hose? or is that bad idea because your therefore giving your motor heated up coolant thats just passed thru the turbo ?
Thanks for your help, if you have any good links that go in to better detail on where to put your coolant return please post if up :D
Thanks
I need a sponsor
Uncle Arthur
Dodgy Award Benefactor
Re: HELP- Turbo-oil and coolant lines
Postby Uncle Arthur » Sat Oct 07, 2006 9:32 pm
rjr666 wrote:where do i grab the oil and coolant from the block of a b6?
[/url]
Do any of you guys happen to know the thread details for this oil bolt?
I want to use it for an oil temp sensor, but need to get either an adaptor, or a new sender (the autometer one I have is too narrow a thread)
sabretooth
Postby sabretooth » Sun Oct 08, 2006 1:09 am
If I remember, and have a matching tap I'll be able to tell you the exact size tomorrow. I would -guess- M8x1.25 but I can't say for sure.
Uncle Arthur
Postby Uncle Arthur » Sun Oct 08, 2006 11:27 pm
sabretooth wrote:If I remember, and have a matching tap I'll be able to tell you the exact size tomorrow. I would -guess- M8x1.25 but I can't say for sure.
Thanks Sabre - turns out it's 10x1.5
sabretooth
Postby sabretooth » Mon Oct 09, 2006 2:32 am
Yep, I checked my block today when doing stuff to it and it is M10x1.5.
