Clutch shudder AND weird rattling noise from gearbox
maxwolfie
Postby maxwolfie » Fri Aug 04, 2006 1:13 am
OK, not only do I have the usual clutch shudder, recently there has been a loose rattling noise as well right as you engage the clutch (not a metallic vibration, its like something is actually completly loose and banging arouind in the gearbox somewhere.......... What could it be? I suppose this is pretty serious and I should take it to someone that knows what they are doing?? :lol:
'89 JDM NA6 (black)
2" s/s ex., 4-2-1 extractors, high flow cat, RX-7 AFM + pod, lightened fly, h/d clutch, 2 way lsd, slotted rtrs, Racing beat type II front bar, Speedy 17" wheels
sirbob
Postby sirbob » Fri Aug 04, 2006 9:15 am
My guess is the throwout bearing...
Sounds like a good time to drop the box and do the clutch whilst your down there!!!
If it is the throwout bearing then it isnt terribly serious, just noisy. But my bet is that the clutch shudder has caused the throwout to die and hence it is prudent to do the whole lot, pressure plate, clutch plate and throwout bearing.
Now driving a Grand Vitara whilst waiting for the elusive Black SE
OMY005
Postby OMY005 » Fri Aug 04, 2006 10:05 am
Likely to be the throwout or spigot bearing. Either way the box has to come out and both can be easily done at the same time. I replaced my spigot bearing just recently. No special tools are required for this as it fits into the flywheel not the end of the crank so its easy to get out when you take the flywheel off.
Andrew. :)
Previously, White 95 NA 1.8 Hard Top,Stock standard
Now, 2016 Fiat 500x, 2014 Fiat 500, 2015 ND GT 2.0
maxwolfie
Postby maxwolfie » Fri Aug 04, 2006 10:17 am
Cool, so one of two cheapo things to replace, just not to cheapo to GET to in the first place... how hard is it to drop the boxes in the NA6's? My last mechanic told me I have to drop the sub frame too ($$$$$$)
How much should I be looking at for both of these to be replaced and laobur (estimated of course)
'89 JDM NA6 (black)
Garry
Postby Garry » Fri Aug 04, 2006 10:29 am
Get a new mechanic. :roll: You can do it at home with basic hand tools. But it's not very pleasant.
Bevan
Postby Bevan » Fri Aug 04, 2006 10:44 am
maxwolfie wrote:Cool, so one of two cheapo things to replace, just not to cheapo to GET to in the first place... how hard is it to drop the boxes in the NA6's? My last mechanic told me I have to drop the sub frame too ($$$$$$)
Don't worry about it. It's not serious. I had that same rattle from the throwout in my last car (NB8A) for a good 10,000km. Just let it go until you need to replace the clutch and then do it all at once. 8)
PS. I never actually ended up fixing it either.
maxwolfie
Postby maxwolfie » Fri Aug 04, 2006 11:56 am
Blaaaaah!
*mental blank, what am I postin about.. oh yeah. my fugged up gearbox!**
Yeah Beverely, I would just NOT fix it, but it's SO fuggen annoying on deceleration and the shudder is AWFUL, I mean, it's really bad.. really really.. bad
lol
'89 JDM NA6 (black)
sirbob
Postby sirbob » Fri Aug 04, 2006 12:44 pm
Just thanks your lucky stars its not a front wheel drive...
I did the clutch on my old celica... Ended up removing 3 of 4 engine mounts and dropping the whole engine 2 inches to clear the wheel arch so i could remove the box...
2 weeks of late night swearing and frustration...
But so worth it for the pure satisifaction of doing something yourself...
ampz
Postby ampz » Fri Aug 04, 2006 3:47 pm
Man you kill me... :D
The clutch shudder is probably due to the throwout bearing being cactus.
Haven't you fixed that yet?
That was like, last year when i told you about it!!! :shock: :lol:
Huh?
Moggy
Postby Moggy » Fri Aug 04, 2006 3:48 pm
I guess you just have to decide if it's that bad that you have to fix it. Of course, you don't HAVE to fix it till the clutch stops working...
If you do fix it, get new throw-out and spigot bearings, and a new clutch disc and plate (should be able to get a decent heavy duty one for $3-400 new) and rip out the gearbox! Only problem is, it's an awkward job, dirty, and not overly fun... If you can get access to a hoist it makes it easier.
