My question is what to upgrade(not just replace) with?
CT wrote: 2. Goodwin big brake kit - 4 wheel kit: Uses wilwood 4 spots on the front with larger rotors and aluminium hats. $2200 which s excellent value
rhysk wrote: The pads I use in my car necessitate replacing discs more pads, but fortunately the discs are cheaper and just as quick to replace. Rhys
kitkat wrote:while were on the subject of brakes...
when i decide (can afford) to upgrade the brakes... should i just get slotted rotors or get the slotted & drilled rotors?
