aircon compressor
JBT
Postby JBT » Tue Jul 25, 2006 8:07 pm
Are you sure it's the compressor or just the compressor drive belt which also drives the power steering. The belts scream when worn. Try rubbing some wet soap on the underside (pulley wheel side) of the belt.....with the engine off. Start engine and, if the noise goes, you'll know it's the belt - easy fix.
If it is indeed the compressor, how much $$ is an unknown but, if all else fails, try the local Mazda dealer for a quote as guidance. Give the finger to, and turn your back on, any of these pricks who start with the \"sports car - difficult - expensive\" BS :evil: . It's a modern Japanese car in mechanical terms and that's all there is to it.
RACQ (member?) might be able to offer some advice too. Let us know how you get on.
Moggy
Postby Moggy » Tue Jul 25, 2006 10:27 pm
If it is the compressor, regassing is usually about $100, labour shouldn't be more than $200 (changing an a/c compressor is dead easy on an mx-5), new belt should be about $20, and I would be unsure on the compressor cost, but I would estimate around $300-$500 if you want to fit a brand new one. Like JBT said, if you ring Mazda they will give you an idea of parts costs etc. So all up should be well under $1000.
CT
Postby CT » Wed Jul 26, 2006 10:29 am
If you need a compressor, PM me. 8)
