NA Turbo Oil Drain Position??
Lucky_Luke
Postby Lucky_Luke » Thu Jul 20, 2006 10:48 am
Hey guys, just a turbo query some of u may be able to help with...
Occasionally ive noticed that after giving my car (1990, 1.6L) a bit of a squirt the boost doesnt seem to be as responsive until driving normally for a bit again ( ie a few hundred metres or so at least) and then it works fine... :?
Im suspecting that it could be the position of oil drain line from the turbo back into the sump... and also that it may be because it is too low in the sump. Is this possible?
If the oil is still being pumped into the housing by the engine and the oil drain line is backed up(ie not draining quick enough) the oil has nowhere to go and i suspect it could slow the turbo and effect its spooling rate???
the oil is supposed to drain out under gravity isnt it? and hence should have a free flowing unrestricted exit point.
I was just wondering if what i just wrote is at all possible and where and how other people with turbos on their NAs have successfully placed the oil drain point.. ive read and seen all the AVO and flying miata manuals which i used as a reference where i put mine.. just under the airconditioner compressor bracket. any other options?? i'd considered the dipstick but am concerned with the flow rate.
Preferably places that dont require the sump to come off... :roll: another big job!
Russellb
RIP Nov 2014
Postby Russellb » Thu Jul 20, 2006 8:02 pm
Usally if the oil is not being drained away fast enough the oil pressure will
blow past the turbo seal and make clouds of smoke
It should not slow down the turbine shaft
May be a Coked up bearing's in the turbo :?:
You could clean it out with carby cleaner. I did that to ny second hand turbo and it was amazing the differance in how easy the turbine shaft spun
My ClubmanRebuild
MX5 SE Rally car is HERE :)
Juffa
Postby Juffa » Thu Jul 20, 2006 11:17 pm
There are not too many choices for where the oil return can go, given that it return is gravity fed. I have mine in the position as recommended by FM, ie 2 inches below the top lip of the sump, so as to clear the AirCond compressor mounting bracket, and close to front of the sump.
I suspect I had a bit of an oil bankup issue as well, so while I was under the car last weekend I made sure that the the return hose had a clear and direct path to the sump...so far so good.
J
Sean
Postby Sean » Fri Jul 21, 2006 8:36 pm
Myfirst attempt was pretty much how the picture above is...
My current set-up is right at the top of the sump - only challenge is getting it in without interfering with the windage tray.
adamjp
Postby adamjp » Sat Jul 22, 2006 1:36 pm
I have 2 NA6 sumps with oil return provision fitted.
If anyone wants to talk with me about price, etc. please email or PM me. I want them out of the garage as they are taking up space.
Adam
