Accessory belt NA8
- Vehicle: NA8 - Turbo
Accessory belt NA8
Is changing the accessory belt/s an easyish job? I've got a bit of belt-slipping noise so I figure its time to give it a go.. I did it on my DR30, it couldnt be much different to that could it?
- sabretooth
Extremely easy. Easier than changing your oil.
Back off the tensioner lock bolt and back the long bolt out until the belt is slack enough to remove. Replace with the new belt and wind the long bolt back in. If you can twist the belt much past 90 degrees then it needs tightening up more. Once you have that bolt done up enough to have the belt tensioned, tighten up the tensioner locking belt.
If you have a 1.8L with power steering and AC, the belts you need are 4PK-940 and 4PK-880.
- JBT
Adam_NAclubman wrote:Air con, no p/s.
Ah well, that makes all the difference. It's possibly just the A/C belt slipping. Is it squealing? Try a bit of soap on the belt and check its tension, that may fix it.
- sabretooth
Done and done
Alternator belt from mazda - $13
They didnt have the air con belt so I had to get that from Repco - $25
Air con belt that came off the car didnt seem to bad, but it looks like when that was replaced they couldnt get the alternator to move, as that belt was pretty shagged, and it took half an hour to get the bottom pivot bolt to move, felt like Hercules had done it up.
No squeaks and squeals now
Thanks for advice
Thanks for advice
