*CHEAP* DIY Cold Air Intakes - Options for the NA
- maxwolfie
OK.. finally had a GOOD look at my engine bay and realised that there is a whole lot LESS room than I thought was there for a U-bend style cold-side intake (Ala Bevan, but he has an NB)
I also have the RX7 AFM (bigger) to deal with, along with a massive pod filter... perhaps I'll have to sit with a smaller one as the current setup is very big
Dont want to fork out for a Mania intake, cant justify spending $600+ on an intake
'89 JDM NA6 (black)
2" s/s ex., 4-2-1 extractors, high flow cat, RX-7 AFM + pod, lightened fly, h/d clutch, 2 way lsd, slotted rtrs, Racing beat type II front bar, Speedy 17" wheels
- maxwolfie
Thanks mate...
Here are some more - same deal though.... When my goddamn phone works ill post them!!! lol
edit: REALLY sh*t quality but you get the point
'89 JDM NA6 (black)
- Sean
2 suggestions, 1 fairly basic, the second farily basic if you can solder.
1 - Remove the L shaped elbow of factory piping that runs across the front of the system and turbo around the passenger side of the engine.
Replace it with a straighter or more flexible piece of pipe so you can run the filter right up behind the headlight - away from the nasty exhaust heat.
2 - Extend teh AFM wiring loom and relocate teh AFM on teh intake side, use same bendy pipe as described above to run a super short intake fron TB, facing downwards towards teh splash guard and mount the AFM and filter down ther - Kind of like slammer's set up if you've ever seen it?
- maxwolfie
Steve 818 wrote:maxwolfie, that's a RB Type 2 nose on your car isn't it??
Follow Sean's instructions for lengthening the cable to the AFM so you can move it away from the headers, then;
See if you can sort out some kind of hose that connects from one (or both) of the great big air inlets in the nose and direct the hose up into your engine bay. Get some dunny pipe wide enough to enclose your pod filter, join it up to your hose from the front and you'll have a custom cheap-assed CAI.
Correct.... I'll have to do alot of planning tho0ugh as I'm a bit of a dumbass when it comes to practical things
'89 JDM NA6 (black)
- Fuzzlet
That or just spend the $290 to have the mania CAI fitted...where did u pull $600 from, or does that include the enlarged piping?
- STV
- Vehicle: ND - 2
- ampz
- Vehicle: NA6 - Turbo
- Andrew
Steve 818 wrote:Post it next to Dave's so we can see the difference between your car with the Mania CAI & steel pipe thingy combined with your Jackson Racing extractors and SP exhaust.
Then we could see the results from Daves car with the rebuilt engine that still isn't fully run in with the factory airbox and intake, and with the factory headers and factory option exhaust.
Then you could post up Sab's dyno graph with his 1.8 having pretty much the same setup as yours and with the results a huge 3 rwkw more then my old 1.6 which had 200,000 k behind it.
Compelling results.
- maxwolfie
ampz wrote:I'll be prepping the corolla on saturday Max...
come round if you have time...
I can probably make something up in under an hour...
and bring the pda back while youre at it
It's a date!!
'89 JDM NA6 (black)
