Due for belt change, what i need?
- Astroboysoup
I'm due for an extensive belt change.. timing belt and those other ones. how many other belts are there?
how much am i looking at to buy the parts.
dad and I are planning to do it next wekend.
parts needed:
timing belt
coolant
thermostat (mines stuck open)
...? what else
is this any good?
http://cgi.ebay.com.au/timing-belt-mazd ... dZViewItem
parts needed:
timing belt
coolant
...? what else
is this any good?
AustCars.net - It's like Facebook but for cars!
- Russellb
- RIP Nov 2014
WATER PUMP
OIL SEALS
CAMBELT IDLER
CAMBELT TENSIONER
AC/PS belt
WATER PUMP/ALT BELT
That should be all
OIL SEALS
CAMBELT IDLER
CAMBELT TENSIONER
AC/PS belt
WATER PUMP/ALT BELT
That should be all
My ClubmanRebuild
MX5 SE Rally car is HERE
- SuperMazdaKart
- jules
- Guitar Hero
Russellb wrote:WATER PUMP
OIL SEALS
CAMBELT IDLER
CAMBELT TENSIONER
AC/PS belt
WATER PUMP/ALT BELT
That should be all
Don't forget the timing belt
And as far as Ebay goes. For something you only change every 100,000kms and is a bitch to get at, I'd suggest getting the bestest you can get, not the cheapest.
You may wish to replace all 3 oil seals. 2x cam and 1x crankshaft. I would.
- Uncle Arthur
- Dodgy Award Benefactor
- Location: Doesn't matter where I'm from-it's that your daughter is with me that's the biggest concern :D
jules wrote:Russellb wrote:WATER PUMP
OIL SEALS
CAMBELT IDLER
CAMBELT TENSIONER
AC/PS belt
WATER PUMP/ALT BELT
That should be all
Don't forget the timing belt![]()
Seesimilar post on 100000km service in this thread.
I didn't do the cam seals, but did do front engine seal. VERY easy but careful job.
Don't buy parts from EBAY - I got all my parts etc from Repco - for piece of mind in case something fails or doesn't fit it is worth it. Not like you can walk into EBAY with the wrong fanbelt and exchange it..... e.g. the timing belt I bought has afull replacement warranty,including the stuffthat goeswrong if it breaks. Try getti g that from EBAY, and at $180, it's piece of mind at not toomuch cost.
And I HIGHLY recommend getting the MX5/Miata Performance Projects Book by Keith Tanner. It is a fabulous howto manual for just about everything you could EVER want to fix on these cars. It tells you what you need, what order to pull it apart in, and more important, how it goesback together.
Budget about $400 for all the parts, and then factor in tools, and food for the service crew. It took me two weekends, but only one day in each, and I made an event of it. I also had to do the waterpump. You could easily complete the full timing belt/drive belt change project in a weekend, in time for the drive in with the lady on Sunday nite.
- sabretooth
- Vehicle: NA8 - Turbo
- Boyracer
- MX-5 Encyclopedia
I reckon if you are doing the job yourself(not paying for labour) just change the belt...thermostat is easy because you have to pull that top hose off anyway.
Like Sabre said,Most of the other stuff like the water pump,idlers,seals, best to check and only change if worn or leaking,lot of this stuff is best left alone.
If you have to change something down the track then it's just a couple of hours of your own time..
I know you like playing with your car Astro.
- Astroboysoup
thanks guys...
im with you Lou and Sab.
thnk i'll just change what I need and have good look at everything else as a check and change them if i need to.
I do know that I need to change some of the other belts because they are starting to get squeaky and im sure that when i pull them off they'll be cracking.
and yeh.. im addicted to eBay.
- jules
- Guitar Hero
- jules
- Guitar Hero
I had a chat one day to Paderaig from Eurocars. He owned the turbo Mariner Blue and is/was the Service Manager at the dealership. He is IMHO a pretty trustworthy source.
He recommended through experience that the Mazda Genuine water pump was better than the aftermarket ones. This was due to him installing an aftermarket one to his car and finding the casting was different and not as strong on design. He also mentioned that the impellor blades were smaller on the aftermarket unit. He took it off and went genuine.
Just food for thought. FRom memory the genuine item is more expensive.
Jules
Jules
jules wrote:FRom memory the genuine item is more expensive.Jules
Mazda pump #MZ-B6BF-15-010F $141.76 (no gaskets)
With club discount from Grand Prix $127.28 (no gaskets)
I forgot to compare the original and REPCO on the dodgy day we just had, would have been a good opptortunity.
Andrew.
Previously, White 95 NA 1.8 Hard Top,Stock standard
Now, 2016 Fiat 500x, 2014 Fiat 500, 2015 ND GT 2.0
- sabretooth
jules wrote:I'm trying to remember how easy the tensioner and idler are to replace later on if they seize or anything?
You can get to them without taking off the pump or belts can't you?
Jules
Yeah, the belt can stay on the car. It might be a bit of a push to get the idler in but that's about it. For what it's worth, my car's done 118,000KM and I'm using the tensioner + idler + spring from my other engine. I'm also using the water pump from when I did my water pump change at around 67k (and put it on the Familia engine when I did the engine swap). I'm not adverse to doing work on my car so if the water pump fails it's only a little bit of labour to replace.
