Ralphff wrote: The car is bog standard and has only done 128k and running on regular ULP.
You'll have to run on PULP with 14 degrees to prevent pinging/detonation.
RRdstr wrote:Like JBT said . . . or, what is working for me is using a fuel catalyst,
RRdstr wrote:Like JBT said . . . or, what is working for me is using a fuel catalyst, and mine runs detonation free at 16 degrees BTDC, and has an increased and nice straight torque curve down low. I chose that way to go so I could stay with the cheaper regular ULP in the long run . . . the fuel catalyst is a bit expensive, but over a period of time, makes sense for me. A bit more drivebility in mid range, which becomes better consumption when dríven gently.
JBT wrote:Ralphff wrote: The car is bog standard and has only done 128k and running on regular ULP.
Alf wrote:
I'm interested but sceptical. Does it still work for the sceptical?
Alf
RRdstr wrote:The Pupat wrote:RRdstr: You're occupation isn't Motorsport Icon is it??
N a a a h . . . not me . . . I wish . . . JB has put his name to this little gismo . . .
