How can i tell if my engines been replaced?
- JBT
initial_mx5 wrote:I tried looking where the diagram says, i cant find it and theres to much...........
Look harder. There will be a flat deck on the rear of the block. The number is not stamped very deeply. Clean the area and get a very bright light. You may need to rub chalk on the flat area to help highlight the number.
Check the other (exhaust) side if you think it may be a BP engine.
- sabretooth
- Vehicle: NA8 - Turbo
Come along to the club run this Sunday. There will be more than enough people there to hlep you find the engine number. By the way that number on the intake manifold is more than likely a part number and I believe that the piece of paper is as well.
J
J
- sabretooth
