jules wrote:$800-$1000 depends if you do the water pump (WHICH YOU SHOULD).
We had a dodgy day up here in Qld on the weekend to do this service for Mikey. I think he got away with about $370.00 for parts and a keg of Heinekin
Jules
Yep - what he said.....
I regularly do my own servicing, and so I know what's been done and when.
For the recent dodgy weekend the work basically included:
timing belt replace
water pump replace
service timing tensioner wheels
reset timing (14 Deg BTDC)
check and reinstall spark plugs (still fine)
tappet cover remove and reinstall (new gasket goo - reuse old undamaged gasket)
New oil and filter
new coolant
Prior to this I had already in separate services:
replaced thermostat
replaced drive/accessory belts
replaced brakes front and rear
replaced gearbox oil
replaced diff oil
serviced airfilter (K&N)
checked coolant hoses and replace where necessary
So yes, for the equivalent of a 200000km service, I did the top list. Cost was $308 for new parts, plus some tools I needed, and food + beer for da boyz - about $400 all up.
If you have access to space, tools,and knowledgeable help, and are able to or know someone who can happily work on cars, then it isn't too big a deal to do your own services - even seemingly major ones.
