Oh god now I've gone and done it... Clutch working on + off
maxwolfie
Postby maxwolfie » Sat Jun 17, 2006 2:37 pm
OK, just finished changing my box and turret oil.. all good... go for a drive up the street...... I notice the friction point is a lot lower than what it normally would be.. OK.. Get half way up the street, peddle goes totally floppy, then I go to corner, pump the clutch a few times.. got pressure again, then it goes back to nothing etc...
No leaks from what I can see!
Maybe I just need to bleed it? How do I do that :shock:
Thanks guys
:lol:
'89 JDM NA6 (black)
2" s/s ex., 4-2-1 extractors, high flow cat, RX-7 AFM + pod, lightened fly, h/d clutch, 2 way lsd, slotted rtrs, Racing beat type II front bar, Speedy 17" wheels
maxwolfie
Postby maxwolfie » Sat Jun 17, 2006 2:39 pm
And the mechanic closed early today!!! Dammit!1
I need to have it going by Monday or I'm screwed! :oops:
'89 JDM NA6 (black)
Craig
Postby Craig » Sat Jun 17, 2006 2:42 pm
The bleeder is located on the side of the slave cyclinder, which is itself located on the side of your gearbox. Give it a bleed first but be prepared for a knackered unit and if it is just buy a new one from Mazda/Repco/Mania etc and know it's done right.
maxwolfie
Postby maxwolfie » Sun Jun 18, 2006 12:46 pm
This is not good..... i need some plastic tubing which I dont have..... hmm
I'm following http://www.miata.net/garage/slavecyl.html
'89 JDM NA6 (black)
maxwolfie
Postby maxwolfie » Sun Jun 18, 2006 1:43 pm
Just made it 100x worse! Now I cant get it into gear at all
ahhh wonderful :mrgreen: AND i have work early tomorrow
'89 JDM NA6 (black)
