Draining the box turret?
- maxwolfie
Is there a way/point? I have some leftover redline that I want to chuck in there, but it's half full of murky crap
'89 JDM NA6 (black)
2" s/s ex., 4-2-1 extractors, high flow cat, RX-7 AFM + pod, lightened fly, h/d clutch, 2 way lsd, slotted rtrs, Racing beat type II front bar, Speedy 17" wheels
- green_comet
- Car Detailing Guru
- bigdog
- King of the kennel
- StanTheMan
bigdog wrote:*Pictures the Wolfman with mouth full of gear oil*![]()
ROFLMAO.....too true
- irwin83r
trick is to stick the tube in fluid first and fill the tube, then plug both ends with your thumbs, then quickly let go of one end and cram it into the fluids deepest point then you should be able to put the end with your thumb on it still into a container at a lower point. this way you dont have to worry about coppin a mouth full might take a go or two to get used to, but after getting a mouthful of who knows what from an industrial pump i was tryin to drain before i stripped it when i was a first year i quickly realised theres gotta be a better... tasting way
