if you have a NB that is not the air filter
Rickster wrote:I still may have to put it on a hoist somewhere to get access to it though. There doesn't seem to be a hell of a lot of room to get hold of that filter.
Rickster wrote:Yes I hope you're right. I've only done one change. Maybe the oil filter was on too tight. I lubricated the new seal before screwed it on... finger tight then a little bit.
btw I'm using Castrol Magnatec 10w-40
Rick
Isn't that bad? I thought it was good for the oil to be discoloured after a while. That means that it's cleaning all the crap from the engine.hot rod wrote:BTW, I switched from Motul to Penrite Sin 5W60 about 6 months ago, even after 4000kms the oil still looks like honey.
Bevan wrote:Isn't that bad? I thought it was good for the oil to be discoloured after a while. That means that it's cleaning all the crap from the engine.hot rod wrote:BTW, I switched from Motul to Penrite Sin 5W60 about 6 months ago, even after 4000kms the oil still looks like honey.
Users browsing this forum: Google [Bot] and 3 guests
