anyone built up the pedal height to toe-heal easier?
Casey
Postby Casey » Wed May 31, 2006 12:07 am
Bend it upwards.
White SP Image
kitkat
Postby kitkat » Wed May 31, 2006 12:10 am
block of wood :lol:
i also have thought about this, i think the brake pedal depth is ajustable but i havent looked into it properly yet... hmm might give me something to do tomorrow.
RRdstr
Postby RRdstr » Wed May 31, 2006 12:15 am
I have lowered the brake pedal height . . . I had the Enthusiasts Manual beside me when I did it, but once you get your head down there, it is pretty obvious . . . :mrgreen:
Rex
Bevan
Postby Bevan » Wed May 31, 2006 11:31 am
bam wrote:and how much longer i gotta be a learner?!?!?!?!?!?!?! :?:
Congratulations, you're now a driver. 8)
CT
Postby CT » Wed May 31, 2006 11:59 am
By adjusting the pedal, you are only adjusting the free play and not the actual pedal mechanism - it will still engage at the smae point. Make sure you still have a little free play otherwise you could be engaging the master cylinder all the time which is not so good for your brakes.
The pedals in the MX5 are pretty good for heel-toe from the factory as they are but offsetting the brake pedal with an aftermarket alloy pedal can be a good solution. I made one out of thick alloy for the race car and it sites about 10mm closer to the accelerator for this very reason. If you do this, cover it in waterproof deck tape from a boat shop so your feet don't slip when wet. 8)
