Hi All,
Just wondering if anyone has done it or know if its possible.
I've already done the NB interior conversion and the only thing left is the speedo/guage cluster. I'm running a Wolf V4 PnP ECU and putting a 6-Speed box.....so it should be possible right? ? ?
Thanks again
Rod.
NB Guage/Speedo Cluster into an NA?
- Roderic
Thanks to:
Alberts Car Stereo-Fabrication/Stereo
Imports 101-Compliance/Mechanical
Miata Mania-Various
MX5 Mania-04 NB Interior
MX5 Plus-Engine, Gearbox, Brakes, Diff
MX5 Parts.UK-Rear Tail Lights
Prestige Motorsport-Importing
Wheelspin-Mechanical
Miata Mania-Various
- CT
- Roderic
Where does the speedo signal come from?
As in where does the cable link to??
Thanks to:
Miata Mania-Various
Miata Mania-Various
- Garry
The tacho works differently as well.
There is a pulse generator attached to the gearbox where the speedo cable would be attached to the NA gearbox. You'd just need to run a wire from that to the new speedo. I'm not sure what you'd do about the ECU speed signal which came off the NA speedo pulse generator though.
- CT
