OK SO YOU WANT TO KNOW
The superchager is an Autorotor
The intercooler is a cheepy off Ebay ( like the one Astroboysoup had)
and I still have the A/C
The engine is brand new I rebuilt it with stock pistons,rod ECT
the manifold has been custom made in house and has been pinned and port matched. It has a set off regrind cams 255 deg with 8.5 mm lift using the STD HLA
Using a Autronic SMC V1.10 Computer and Toyota 4AGZE injector
Has a 6sp Box 1.8 torsen Mazda speed coil overs ( Ebay again)
Custom 4 into 1 tuned length Extractor and a 2 1/2\" SS system
on the test run tonight we made 5psi of boost at 3000rpm and a bit over 7psi at 5000 rpm
It is wet hear in canberra tonight but O MY GOD this thing is hauling arse
and it only has 17deg ignition in it under boost
will be on the Dyno next week to get some figures
Now please wipe the drule of the Keyborad
