Trouble starting
zorak
Trouble starting
Postby zorak » Mon May 29, 2006 8:35 pm
Hi everyone - My mazda has had difficulty starting for the last couple days. It will only start if I have it in gear with my foot on the clutch. The car runs perfect once its going. The engine seems turning over with enough power so I dont think the battery is the problem. Any ideas on what I should check?
cheers
NB8A
WP 1:10.69
SMSP (south) 1:04.41
SMSP (GP) 1:53.98
Postby Okibi » Mon May 29, 2006 8:53 pm
As soon as you have the clutch in, it starts perfectly every time?
zorak
Postby zorak » Mon May 29, 2006 8:58 pm
nah it still cranks longer than normal - but its seems to be the only way it will start. The last couple mornings it has failed to start, and then if I try again with my foot on the clutch, bam away she goes.
NB8A
WP 1:10.69
SMSP (GP) 1:53.98
sabretooth
Postby sabretooth » Mon May 29, 2006 9:32 pm
Are you sure it's not just coincidental?
AJ
Postby AJ » Mon May 29, 2006 9:39 pm
sounds coincidental to me too 8)
XMX5 Rogues
Alf
Postby Alf » Tue May 30, 2006 12:57 am
The bit about having it in gear is strange! Are you sure it won't start in Neutral with your foot on the clutch? Hard to imagine how the disconnected gearbox has any effect.
If you leave the car idling in Neutral, and press the clutch in, do the revs change by 100RPM or more or do ou hear clanking noises?
Alf
2015 ND MT GT Crystal White Pearl Mica (pic to come)
Adam_NAclubman
Postby Adam_NAclubman » Tue May 30, 2006 3:01 am
Sounds like its turned into an Excel
zorak
Postby zorak » Tue May 30, 2006 5:44 pm
Problem solved - I had a new immobiliser and alarm fitted to the car last week (the old one broke) which cuts the fuel up until 30 seconds after the car has been unlocked - hence the reason it has been taking a long time to start. The clutch thing was purely coincidental :oops:
I am going to have to take it back to the auto electrician and get the fuel cut off part of the immobiliser removed.
NB8A
WP 1:10.69
SMSP (GP) 1:53.98
