clutch
namster
clutch
Postby namster » Sat May 27, 2006 7:49 pm
lost clutch pressure, hard to select first... =(
track day coming up =(
~ ouch =::(
** forum search indicates this is a failure of clutch slave cylinder?
zoom zoom zoom...
Russellb
RIP Nov 2014
Postby Russellb » Sat May 27, 2006 9:39 pm
Sound like your clutch slave has died
mania have a recon unit for $36 exchange
or a new on for $98
My ClubmanRebuild
MX5 SE Rally car is HERE :)
Moggy
Postby Moggy » Sun May 28, 2006 1:47 pm
Same thing happened to my car, I just replaced the seals in the slave cylinder with a $10 kit from repco... 1 hr job. That's if it's the slave cylinder, which it usually is.
Garry
Postby Garry » Wed May 31, 2006 11:39 am
do u get a whistling/chirping sound that stops when u put ur foot on the clutch?
You need to lubricated the end of the little rod that comes out of the slave cylinder. Usually the end that pushes against the clutch lever, though sometimes the end that contacts the slave cylinder can squeak too.
